Coolant leak
Coolant leak
Postby senftarnaud » Tue 28.08.2012, 10:36
Hello,
I have a coolant leak.
I found the source of the leak.
It is the junction of two pipes black bottom.
But what should I do? Change the pipes?
And if so do you know where I can order them? Is this standard pipe or specific to Lotus.
Thank you in advance for your answers and have a nice day
senftarnaud
Re: Coolant leak
Postby cliff » Tue 28.08.2012, 14:53
Lotus use these to join pipes together.
On the left is what they should look like, on the right what mine (and probably yours) did look like. There are 2 of them in the cooling system, worth replacing both. Lotus part number: B075K0111Z.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
