running too rich
running too rich
Postby Quanta » Fri 14.09.2012, 20:52
Hi, new Elan owner. Much recent work done since purchase like timing belt, water pump, thermostat, CAS, various seals, etc. To pass CA smog I just did the O2 sensor and CAT. I failed again and am definitely running too rich. No new error codes as the 41,13 and 45 have cleared, but still too rich. Now that I've got a new CAT in there I'm worried about burning it up running rich so I want to get this sorted ASAP. Does anyone have any insightful suggestions for what to look at next to have the ECM signal a leaner mixture? ANY and ALL suggestions are greatly appreciated!
Quanta
Re: running too rich
Postby HJ2 » Fri 14.09.2012, 21:01
Perhaps start with a good reading in my threat here:
viewtopic.php?f=37&t=21004&p=267217#p267217
Good luck!
Postby Robert_P » Sun 16.09.2012, 16:32
I ran into this same problem after messing with the engine's top end and piston rings.
Due to oil being pumped through the engine exhaust from suspected badly/poorly installed valve seals by the machine shop and rings that hadn't seated yet, it probably killed the O2 sensor in mine.
For the record, as the engine begins to tighten up and seal, I have gone through three O2 sensors, and two Cats. Read somewhere that the Cat can sometimes be 'recovered' by soaking it in hot water and laundry detergent, followed by a good flush/rinse and blown out with compressed air. Did this with the one new, oil saturated Cat but haven't swapped it out with the second new one that seems to be still working. Once I get the engine running 100% one of the Cats will be throw-away and sold for it's precious metal content along with the 21-year-old original that should almost balance the cost of replacing the CAT twice.
As a systematic approach to figuring out if anything else was causing the engine to run rich, I replaced the temperature sending unit, ECT, TPS, IAT, MAP, O2 (third one) and the fuel regulator on the fuel rail. Guessing and swapping parts is never a good idea, but in the absence of good diagnostic tools it is an alternative as long as cost does not run away. All these sensors only cost about $70 US and since the diagnostic tools to read the ECM in real time do not exist anymore (except perhaps on eBay) I figured it was a good way to troubleshoot and eliminate as many root causes as possible.
I also replaced the coil at the same time. Engine straightened out and now runs reasonably well except for the oil puffing at start up that I hope to address on Monday next. One very important step is to check and shine up all of the grounds on the engine. On the 4EX1 there is one from the back of the intake to the right shock tower, and two on the thermostat housing for the ECM, finally one attached to the coil bolt as well. Shine them all, clean the surface they attach to and snug the bolts down tight. Also replace any vacuum lines as ours were over 21 years old.
Another thing I can share is that the Bosch O2 sensors seem to be a little more forgiving relative to oil or rich fuel mixtures. I have one in reserve (they cost about $10 USD from Rock Auto). I think they work better than NGK / NTK sensors too.
Finally, the ECT sensor is the center of the fuel and ignition system. If it is not delivering proper voltage signals to the ECM, the ECM will be all over the map concerning spark and fuel delivery. Even a good O2 will not be able to compensate for a rich mixture. Earlier Hyundai vehicles also suffer from this same problem.
One more thing, our 1991 has a non-heated O2 which means it will run open-loop until the O2 heats up. And the O2 can go open-loop at idle too. Most of the DOHC engines use a heated O2 so this should not be an issue.
Robert_P
Postby HJ2 » Sun 16.09.2012, 18:28
Did you do adjustments to the CO pot? (See Wiki ;-)
Did you start with the basics (Base timing and adjustments of the CO pot, assuming it concerns an SE)?
Any cracks / holes / bad gaskets anywhere in the exhaust traject?
Postby Brit-Car-Nut » Sun 16.09.2012, 19:32
Strange. My O2 sensor is a 4 wire, heated device.
Postby Robert_P » Sun 16.09.2012, 22:33
Brit-Car-Nut wrote:Strange. My O2 sensor is a 4 wire, heated device.
Yep, the heated O2's have multi wire. The non-heated has only one.
Robert_P
Postby ESM » Fri 21.09.2012, 08:45
A faulty coolant temperature sensor (CTS) or mass air temperature sensor (MAT) are known to force the car rich. If you have ElanScan check both these read close to ambient temperature after the car has stood overnight. Note: the CTS does not drive the dash temperature gauge so that is no help in diagnosing a CTS issue.
ESM
Postby tigerdog » Mon 24.09.2012, 23:31
Robert_P wrote:...since the diagnostic tools to read the ECM in real time do not exist anymore
Look around the forum for ElanScan. This is a PC-based diagnostic tool that does read the ECU in real time and also serves as a datalogger. Developed by our own ESM (Alan) with cables supplied by Mr. Smith the Kitty Fiddler, it's an invaluable tool. If you're still unable to find the cause, it's worth picking up the cable, downloading the free program and setting up on any old windows laptop you can lay your hands on.
