kuching hardtop
kuching hardtop
Postby shane » Tue 30.10.2012, 21:13
Hi,i have a hard top that i bought last year which has an inner lining.this has started to come unstuck.any one out there know the best product to fix it.would like to get it sorted before it goes back on the car.
shane
Re: kuching hardtop
Postby Gary1958 » Wed 31.10.2012, 11:25
When I replaced the headlining on my Lotus Excel I used this stuff from "Woolies" and it worked very well with no sagging.
http://www.woolies-trim.co.uk/p-1332-adhesive.aspx
Gary1958
Re: kuching hardtop
Postby Gareth » Wed 31.10.2012, 14:29
I had the same problem with my hard top : the lining Simon installed started to "sag" : I pulled back the front lining (windscreen end) then "hung" the hard top from the ceiling of my Garage (as if the top was in position on the car) using 4 nylon cords and "S" brackets.
I then pulled the loose lining away from the roof, which created a sort of "tunnel" and then used a high temperature spray adhesiveon both surfaces, allowed to dry for 5 minutes and "smoothed" the lining back in place (working from front to back) using a plastic body filler card and wallpaper seam roller.
So far, it seems to have worked!
:D
Gareth
Gareth
Re: kuching hardtop
Postby shane » Wed 31.10.2012, 23:48
Gareth wrote:I had the same problem with my hard top : the lining Simon installed started to "sag" : I pulled back the front lining (windscreen end) then "hung" the hard top from the ceiling of my Garage (as if the top was in position on the car) using 4 nylon cords and "S" brackets.
:D
can you remember what type of adhesive you used Gareth,and where to get it from,i think the spray idea would be best as you would probably not have to pull too much away,
cheers,
Shane.
shane
Re: kuching hardtop
Postby shane » Wed 31.10.2012, 23:50
Gary1958 wrote:When I replaced the headlining on my Lotus Excel I used this stuff from "Woolies" and it worked very well with no sagging.
Thanks for that Gary
shane
Re: kuching hardtop
Postby Gareth » Thu 01.11.2012, 11:37
Spray Adhsive I used was : "Woolies" : High Heat Resistant Aerosol adhesive : IIRC circa £8
1 Can should be enough
:D
Gareth
Gareth
