by chrisP » Mon 26.11.2012, 18:38
Could anyone recommend a metal plating specialist in the UK, (In Hertfordshire or close by would be even better). I want to have various metal brackets from my car cleaned and replated in the gold factory finish, while it is taken apart for a winter refresh and repaint.
chrisP
by GeoffSmith » Mon 26.11.2012, 20:17
Sorry for not replying to you PM Chris. I used
Avon Electro Plating in W-S-M. They quoted me £20 for the radiator brackets over the phone but charged a very reasonable £40 for everything below:
- Kitty Fiddler
by chrisP » Wed 28.11.2012, 11:02
Hi Geoff
Thanks for the information, did they clean/shotblast the parts, before plating as well, or did you do that yourself?
chrisP
by GeoffSmith » Wed 28.11.2012, 16:57
They stripped and cleaned everything. If I'd known in advance, I would have removed the paint on the rad bracket with paint stripper as they took weeks over that - one problem of giving them a small job at low cost I guess.
- Kitty Fiddler
by GeoffSmith » Sat 11.01.2020, 12:08
For the benefit of ConfusedOfCrudwell, there is also
S&T in Yate. They were more expensive just for the radiator bracket but if I had ever got my roll hoops plated, I would probably have used them.
- Kitty Fiddler
by Simon_P » Sat 11.01.2020, 14:24
Not many parts were in the "gold factory finish" which is "Zinc and Yellow" when you ask a plater.
Depending where you are in Hertfordshire.
RCJ Metal Finishers who I have used several times - good results but they can be slow
and there are 2 in Arlsley one has a good reputation
3 things with any platers.
1. Take a list and photos of the parts
2. The finish achieved is only as good as the base article so if you take in clean de-rusted parts you are likely to get better results. They will go through paint stripping and derust and several cleaning processes, but if they are covered in cack it is unlikley to completely clean the corners. Previously plated parts go through an acid strip process. rust will show up dull as the surface is pitted.
3. Ask how much and particularly when. RCJ for example are a big commercial platers so if they are busy you will wait.
The grey "paint" is an epoxy coating a lot of paint strippers wont touch it.
by Simon_P » Sat 11.01.2020, 14:29
Geoff, why are replying to an ancient post? have I missed something or did I just waste my time?
by Saltire » Sat 11.01.2020, 21:21
Simon: Confused of Crudwell saw the same photo posted on Facebook earlier this week and will have a lower rad bracket to plate or coat later this spring.
Geoff: thanks for the info
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by GeoffSmith » Sat 11.01.2020, 22:17
Sorry Simon, 'tis as Jonathan says. This being LEC however, Chris might still make use of your information!
- Kitty Fiddler
