cornbeef wrote:So I just joined and even introduced myself in the new member section. I looked at a federal m100 today that needs some TLC. It's great looking from 20ft but any closer its shine fades....
It kinda fits what I'm after but buying it comes down to price and in particular how much those big items are to right and hence why I'm here. The three things that are of concern
Welcome! I'm sure loads of helpful people will be along shortly...
cornbeef wrote:1 finding a federal rear taillight as I know they are like hens teeth
There have been a couple of cars bite the dust in recent history, someone here may be able to help. I seem to recall there was a red one with the front crushed by a truck? Also a yellow (in Canada?) which took a large deer/moose to the bonnet... my point is, they might be rare but this is probably the best place to find one. Also keep an eye out for parted out or knackered Renault Alpines.
cornbeef wrote:2 the power steering has a leak - looks like the rack, how much of a headache is it to replace and will non US racks work? Or can they be rebuilt?
I believe LHD racks are still available (or were recently) from the Lotus aftersales list for a very good price. Even if not, there are plenty of places that'll refurb a rack and return it good as new for a reasonable fee, even in post-industrial Britain so you shouldn't have too much trouble in a good practical country like the US. I assume you're in the US?
cornbeef wrote:3 finally the brakes. The pedal is very soft at the top and then once it firms up it needs a massive shove to stop it (fells like a cable operated brake), so any suggestions on what might be going on there would be welcome.
Welcome to the Elan dodgy braking club! If the rest of the car's in need of TLC, I'm surprised the brakes work at all... There are several options.
The rear brakes will seize up over time. The sliding pins can be refurbed given a little time and some cheap parts, and will probably improve matters quite a bit, particularly with respect to the parking brake. The rear discs can be tricky as they're of one piece with the hubs. They don't wear much, but you may have to have them skimmed if they're rusty. When they get too thin, you'll either have to get new (fairly expensive) parts from Lotus, or find a kit to convert to a normal hub and disc arrangement - this might also be expensive, but at least you can expect replacement discs to be cheap in future. There have been projects to manufacture such kits, but you may have to find a friendly machine shop.
The fronts are more serious, and influential as they do most of the braking. These calipers can also get sticky, and a refurb will often do wonders, but that'll only really get you to just about adequate. Good pads will improve matters noticeably but many people find that the only way to get confidence-inspiring braking performance is to upgrade to four-pot calipers and bigger discs. I believe the best options vary depending on your country, but Hi-Spec, AP and Wilwood potentially give routes to good Elan braking. You'll find loads of information in the "Suspension and Brakes" forum.
cornbeef wrote:Other than that it has a few of the little m100 items that youd expect to see and on the plus side it has had a number of m100 issues sorted but I want to get a grasp on 2 and 3 before making a fair offer
What are the other niggles? Some seemingly minor things can be quite tricky to resolve, whilst some seemingly major things are really very straightforward.
Enjoy!
Adam
