Starter problms
Starter problms
Postby davidjt » Mon 22.04.2013, 16:57
Still struggling with various electrical issues, and now the starter is playing up! Battery is fully charged, fuel pump chugs away, starter then turns over, but sounds really feeble - too feeble to do anything - but eventually the engine fires and runs normally. From past experience, a loose connection at the starter can cause intermittent problems, but this sounds/feels like a starter on its last legs. Anyone had any similar symptoms?
(On a different topic altogether, I will get postage costs for the uprated springs for those who have enquired: best offer so far is £50.)
davidjt
Re: Starter problms
Postby Brit-Car-Nut » Mon 22.04.2013, 17:21
Often, the connection issue is inside. The solenoid is a common culprit. Here is a repair kit that replaces the often burned parts in the main solenoid switch area:
http://www.ebay.co.uk/itm/LOTUS-ELAN-1- ... 927wt_1162
As they wear out (burn up), the starter acts like the power feed or earth are lacking.
Not recommending this particular sale, just suggesting the kit is a DIY project and parts are available.
Re: Starter problms
Postby muley » Mon 22.04.2013, 19:08
Re: Starter problms
Postby muley » Mon 22.04.2013, 19:44
Re: Starter problms
Postby Brit-Car-Nut » Mon 22.04.2013, 21:25
The starter is the same as the Isuzu and Geo with the gear reduction starters. In the US, I found a few rebuilt units for $29.99 each + shipping. Alternators, 90A so a bit larger but according to recent posts fit OK, are $40.00 each + shipping. They look to be very nice rebuilds - at least very clean and look to be well handled.
Re: Starter problms
Postby muley » Mon 22.04.2013, 21:39
Just be aware that the Geo Storm alternator I bought does NOT fit the M100 Elan.
Maybe I was unlucky..
Re: Starter problms
Postby Brit-Car-Nut » Mon 22.04.2013, 22:24
I went by the part numbers that were included with the postings and Wiki.
I have an early Elan alternator and it is a little bit smaller in power (50A) and in diameter but other posts said they were able to make the 70A version work with a little prying.
The rebuilder referenced a unit that was listed for both the Impulse and the GEO Storm GSI.
I won't have my spare engines or other parts for a few more weeks but intend to assemble enough to verify all of the parts fit as described.
Re: Starter problms
Postby davidjt » Tue 23.04.2013, 14:32
Thanks for all the helpful replies - and I assume from the absence of recons on SJ Sportscars list that they're not generally available in the UK, so it looks like an import or a diy job. I'll investigate both options. I need the car for a longish trip in a couple of weeks, and hate driving with fingers crossed, so every incentive to get it done!
(My brother has promised that sailing a dragonfly downwind is the yachting equivalent of having a turbo - we shall see.)
davidjt
Re: Starter problms
Postby ovi » Tue 23.04.2013, 17:48
davidjt wrote:(On a different topic altogether, I will get postage costs for the uprated springs for those who have enquired: best offer so far is £50.)
viewtopic.php?f=3&t=21829&p=274996#p274996
I have posted a time back a few questions! :poke:
ovi
Re: Starter problms
Postby Brit-Car-Nut » Tue 23.04.2013, 20:17
davidjt wrote:Thanks for all the helpful replies - and I assume from the absence of recons on SJ Sportscars list that they're not generally available in the UK, so it looks like an import or a diy job. I'll investigate both options. I need the car for a longish trip in a couple of weeks, and hate driving with fingers crossed, so every incentive to get it done!
You can check for the solenoid contacts being damaged without much trouble (after removing the starter) as the damage will be obvious. This is an easy test/repair (after removing the starter).
The Wiki page describes the entire process. Seems the TOP bolt holding the starter is the hardest part.
The basic starter is standard GM/Isuzu. A local rebuilder should be able to get any parts it needs.
Look at this listing to see other makes & models that use the Denso starter: http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 1134069218
The cost to ship to the UK is crazy for a full assembly but individual parts might be reasonable.
Maybe have a local rebuilder look at it and then decide?
