lost reverse gear
lost reverse gear
Postby sprogg7 » Sun 30.06.2013, 14:38
hi guys
my local garage phoned me on friday to say they have "lost" reverse gear on my lotus following some work on the drive shafts and wheel bearings. i think but cant prove that they drove the car to the mot station with out refilling the gear box will oil. my question would be - does my guess about the reason the "reverse gear" as gone seem about right (lack of oil) and if the worse comes to the worse do you know where i can get a re-con gear box.
and last of all should i have stuck to my mk1 mx5
cheers
sprogg7
1990 lotus elan m100
1998 mgf vvc
sprogg7
Re: lost reverse gear
Postby Fetnas » Mon 01.07.2013, 13:59
If they removed one of the bolts from the top of the selector box on the top of the gearbox thinking it was the filler plug, they will have upset the reverse gear interlock that stops the gear leaver from accidently shifting into reverse when shifting down from 5th.
I had the same problem when I changed my gear cables and took out this bolt thinking it was one of the fixings holding the selector box in place. The gear stick wouldn't go into reverse and would get stuck in 5th (or something like that!). To fix it I had to take the selector box off and partially dismantle it in order to rotate the spring loaded cam into the correct possition. I seem to remember there was only 1 other way the cam could sit.
I doubt low oil would cause this problem, someone posted on here that they changed their gearbox oil only to find that there was only about 200ml in there but it still worked, probably not the best for ware though!
I hope this is the fix you need as it's pretty easy to do, almost a easy as the mistake of removing that bolt! :?
Good Luck
Fetnas
Postby Denny » Mon 01.07.2013, 15:09
The garage has more than likely disturbed the gear cables or selector box as Fetnas has described.
i would take it back to the garage and get them to put it right at their own expense!
Denny
Postby sprogg7 » Wed 03.07.2013, 18:48
thanks guys...i let you know what happens
1998 mgf vvc
sprogg7
