NA not playing
NA not playing
Postby ghunterglas » Wed 18.12.2013, 15:13
Hi all, bit baffled & looking to pick brains,
I took the car out yesterday for the 1st time in a few weeks, started first time,
drove 30 miles to a meeting, when i got back to car after a couple of hours it wouldn't start.
turned over for ages but no ignition, managed to push it round & ran down a hill where i bump started it.
it ran at about 3000rpm for half a mile & then died,
called breakdown service ( top service from footman james insurance !) who came out, cleaned distributor/ rotor arm & changed plugs,
managed to get the car to run briefly, again it was fine revving high but when i let it get to idle it spluttered a little & cut out,
had the car recovered to mates garage in glasgow last night,
it started 1st thing this morning but wouldn't start again.
any ideas ? anyone had similar issues ?
any help appreciated
G
ghunterglas
Re: NA not playing
Postby Brit-Car-Nut » Wed 18.12.2013, 15:26
Bad Coil, Bad ignition Module, Bad Fuel Pressure Regulator, Bad Fuel Pump?
When it doesn't start do you have spark?
If not, do you have power to the coil? If not relay or fuses? If yes, bad coil or ignition module OR dirty connections between parts.
If yes, is fuel pressure OK. Bad regulator can cause either low or high fuel pressure issues.
Re: NA not playing
Postby tb10 » Wed 18.12.2013, 18:28
Funny you should post this. My NA wouldn't start on Sunday for the first time since ownership. When cranking, you could smell fuel so that was getting through. Can you smell fuel when cranking yours? I sprayed the leads and coil and the car started.
As I say, I've never had that before. Could your problem be earth related?
tb10
Re: NA not playing
Postby ghunterglas » Wed 18.12.2013, 19:37
Thanks for replies. I'll speak to mate tomorrow,
There was definitely fuel getting through, plugs were wet & the exhaust had a whiff of fuel
I could hear the fuel pump when I switched ignition on,
Quite annoyed as it was running brilliantly on way down.
Cheers g
I'll post findings as & when there is anything to report
ghunterglas
Re: NA not playing
Postby Jeemy » Wed 18.12.2013, 21:08
Sounds electrical given the fact the fuel system seems to be running (too) well, and the fact it just went squiffy with little warning after a long run, sounds like something in the ignition electrics or earth system got dislodged or wet. Sounds like a T&E fix.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Re: NA not playing
Postby Oliver » Fri 10.01.2014, 22:49
In my case it was the igniter in the distributor body. Imtermotor 15875. Just ebay it. Cheap as well.
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Re: NA not playing
Postby Oliver » Fri 10.01.2014, 22:54
The N/A distributor main electronic parts are Daewoo Nubira. Worth a Google.
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
Re: NA not playing
Postby ghunterglas » Wed 15.01.2014, 14:58
thanks for replies, all sorted & prize goes to Steve Roberts at SJ Sportscars for coming up with Coolant Temp Sensor as culprit.
( there's not really a prize ) first time i'd ever broken down too, followed swiftly by the landrover blowing a hose off the turbo the day after boxing day !
getting good at loading cars onto trucks !
happy new year.
G
ghunterglas
Re: NA not playing
Postby rip » Wed 15.01.2014, 20:45
Jeemy wrote:Sounds electrical given the fact the fuel system seems to be running (too) well,
Oh dear. BIG clue missed.
It is a pity Elanscan does not work with an NA. This would have shown a failed CTS quite clearly.
Re: NA not playing
Postby ghunterglas » Fri 14.02.2014, 01:22
resolved but gutted at inconvenience. I can forgive as its SO much fun when performing normally !
- been thinking about this, what's amazing is that for a 24 year old car it is just so reliable and requires such little maintenance.
unlike the landrover ! which is turning into a clown car after 4years.
G
ghunterglas
