S2 Centre Console Fixings
Postby Simon_P » Fri 25.08.2023, 12:34
I've finally fitted the heated seat switches (only about 8years). It's some time since I took the centre console out and I put it back with just the screws in a hurry.
I can't find all of the bits but I think it's 2 thick washers glued together, tube, then a wider washer on top of the tube - is that correct? And does anyone have pictures or dimensions?
The rear I have lost but I think it's only an M5 screw and a washer - pictures or dimensions would be appreciated.
Re: S2 Centre Console Fixings
Postby Saltire » Fri 25.08.2023, 15:23
Mine’s back in now, Simon, and I’m not taking it off again, even for you :lol:
I had an M5 hex head bolt at the back, with a washer under the bolt head. At the front, I had a single washer on top of the trans tunnel, tube on top of that, and two washers ‘twixt tube and underside of console, then the hex head bolt through the lot. Can’t recall the bolt size, sorry.
Postby Simon_P » Sat 26.08.2023, 12:55
Thanks Jonathan - Reassembled it didn't fit properly with the Double washer at the bottom of the tube. I have to take it out again so will write what I used. I have a second set so reasonably confident they are correct except for the double washer Which I only have one.
