Warning Light on Dashboard
Postby DaKa » Tue 12.09.2006, 14:07
The main warning light is now permanently on when I run my 1990 Elan SE Turbo.
It started to come on intermittently (on braking) and then go out again quickly.
I topped up the brake fluid (although I could only fit a couple of tablespoons full in) and the problem went.
It is now back albeit the front pads/discs are brand new and the fluid level is max.
Any ideas as to what else may be causing the warning light to stay on? :?
DaKa
Postby theelanman » Tue 12.09.2006, 14:58
which light????
just unsure as to which light you mean.....
the 'tell tales' which you need to worry about are
the brakes (an apostrophe in a circle)
oil pressure (an oil can)
battery (a pic of battery..means not charging)
catalyst over heat (looks like a BBQ)
engine check (sort of box witha lightnening bolt through it)
these are in that order across the dash.....which one???
cheers
G
ps Ive missed out washer bottle, handbrake, indicators etc etc etc
Postby DaKa » Wed 13.09.2006, 13:49
Sorry, it's the Brake light (circle with apostrophe).
I'm going to check the connections at the resevoir now I think about it.
Do the rear brakes have any sensors for low wearing pads? Ive only ever seen them at the front on other cars - I didn't see any connections when I replaced the front pads recently?
DaKa
Postby DaKa » Mon 18.09.2006, 11:51
Not received the feedback I'd joped for here.
I can't get the brake warning light to go out!!
The full story is that I recently changed the front disc and pads (kevlar and slots upgrade) - standard disc size existing calipers.
Can someone guide a novice like me please?
Is there a brake sensor attached the the front/rear breake pads that I missed? I think not.
Is there a sensor in the resevoir? I think yes, but cannot see any connection.
Normally there is a connetor on the cap of the brake fluid resevoir when this is the case - I don't seem to have anything.
Is it possible that I knocked it off when undoing the cap and it has dropped somewhere?
Any help/images on where/what the brake fluid sensors are would be welcome - otherwise its the garage.
DaKa
Postby Sy V » Mon 18.09.2006, 12:09
Is your brake reservoir absolutely full to the brim...if not, this will cause the light to be on.
Postby DaKa » Mon 18.09.2006, 14:06
It's almost to the brim - I'll fill it right up and see what happens!
Does anyone know why it should be like this?
Why does it have a maximum level mark?
DaKa
Postby DaKa » Mon 25.09.2006, 13:29
Brake fluid reservoir up to the brim but the sodding light still won't go out.
Any ideas?
Was thinking of replacing the brake hoses with steel braided and using the opportunity to bleed out the old fluid. Get the feeling the light will still stay on!
DaKa
Re: Warning Light on Dashboard
Postby DaKa » Wed 10.09.2008, 12:15
Never did manage to get the light to go out - I've just got used to it being on.
Can someone simply confirm whether the brake fluid resevoir has a sensor attached to it - Yes/No?
Any other ideas welcome.
Keep the spirit alive.
DaKa
Postby ailwyn » Wed 10.09.2008, 12:19
There is a sensor in the reservoir, towards the rear.
Postby kurgen » Wed 10.09.2008, 15:34
Does the handbrake use the same warning light? If so it could just need the switch repositioning :-)
kurgen
Postby DaKa » Wed 10.09.2008, 16:19
A question that I'm sure many know the answer to but I will need to check - However, what do you mean by 'repositioning' the switch?
DaKa
