Hey everyone. I'm in the USA and the car is also American, so please keep that in mind for any tips or advice you might have, I appreciate any thoughts.
I'm helping a friend try and get to the bottom of why their Elan will not start. He was driving the car and it shut off on him. Before bringing me into the situation he tried a new fuel filter, and verifying the fuel pump is working, verifying function of the inertial switch, checking for blown fuses, and a few other things. Since that time I have also re-verified those areas.
At the end of my testing, it appears that the ignition and mechanical aspects of the car are both as they should be. The car will crank up and run pretty much indefinitely when given an outside source of fuel (something like starting ether), and I've verified that the pump is working, and fuel pressure is making it to the fuel rail. However, when I checked with noid lights at the fuel injectors, they were not pulsing.
I've seen this behavior from malfunctioning immobilizer systems, except I'm not familiar with an immobilizer system that would allow a car to shut-off WHILE driving. So I'm currently unsure as to whether I'm looking at an immobilizer circuit issue or perhaps an injector driver issue failure in the ECU, or possibly a wiring continuity issue.
I'm looking for the following information on the immobilizer circuit; component location, testing methods if there are any, and a way to bypass it at least for testing. Also some better circuit information on the ECU system wiring diagram and component locations.
I'm looking for similar information for the ECU and it's wiring too. I'd like to verify continuity in the circuit for fuel injector 12v source and grounding/pulsing signals from the ECU as well.
Once again, this is for a North American version of the car. So I know components are located in different locations and wiring colors may be different. Thanks for any and all help.
