Fault Code 42 - Car not firing on all cylinders
Postby Galsia » Wed 19.12.2007, 22:52
Galsia
Postby Monty » Thu 20.12.2007, 00:20
If it`s not Coils it could be the Hall Effect Sensor inside the CAS which can be ordered from Lotus for around £20
Postby Galsia » Thu 20.12.2007, 08:16
Galsia
Postby paulwatkins » Thu 20.12.2007, 08:59
Galsia wrote:Is there a link available for the Hall Effect Sensor?
Galsia.
CLICK ON THIS LINK
Click on the link to the parts list.
The Hall Effect Sensor is on page 11, about half way down the page and is listed for £20.
To order, you need to click on the link to the order form on the original link I gave you, print it out, fill it in, and fax it off! :lol:
Hope this helps, Paul
paulwatkins
Postby Galsia » Thu 20.12.2007, 12:42
Galsia
Postby Dave Eds » Thu 20.12.2007, 12:58
My guess would be if the coil fitted a turbo as well it wouldn't be listed as NA.
Clemo or Oliver may confirm.
Wishbones - cant help but some one will :wink:
Postby Paul.P » Thu 20.12.2007, 13:22
Thought these coils were available from lotus, but you had to order the esprit ones, but they were the same. There was lot of talk about this on here somewhere, but can't find it ?
Postby rip » Thu 20.12.2007, 14:41
Galsia wrote:Also, I need to get my front wishbones sandblasted at some point and noticed that Lotus are selling them for £57 each. Would it be worth picking some up? Are they the only part of the wishbones?
I don't know for sure, but that sounds far too cheap to me. Rears are several times that. Have a trawl through the Suspension section. There may be some useful info there.
Postby Paul.P » Thu 20.12.2007, 17:45
Would imagine there the uppers RIP, the lowers are similar price to the rear lowers.
Postby dapinky » Thu 20.12.2007, 18:27
Having bought a complete set (now just needing one TCA) during the past 12 months I can confirm that the listed pert is only 1 half of the upper wishbone.
To get the whole lot, ideally you need 4 upper bits, 2 lower bits (Track control arms) and a vertical bit!!!
Most parts are 'handed' but one of the upper wishbone bars are common to both sides.
Mostly, the bits at the top don't rust structurally, but might just need rubbing down and painting - it is just that i wanted to do the whole lot at the same time :roll:
Postby Galsia » Mon 21.01.2008, 09:18
Galsia
Postby GeoffSmith » Mon 21.01.2008, 13:44
If you can get it to do it at night, you could take a look at the coils, HT leads and plugs to see if you can see where it is breaking down.
Temporary (or regular maintneance on a Mini where the distributer is right behind the grille and there is no radiator in the way) solution is to spray WD40 but make sure you've run the engine and got it warm to drive out the moisture. Otherwise, you'll just trap it where you don't want it.
Postby Galsia » Tue 29.01.2008, 20:51
Galsia
Postby paza1 » Tue 29.01.2008, 23:29
IIRC you can't see the bolts from above so doing it by feel and/or using a small telescopic mirror is the way to go. Move the header tank out of the way as much as poss. Can't recall whether I used a long reach socket or flexible ratchet spanner (think it was the socket). Take note of the wire to the baseplate and the important insulating washer (careful you don't drop it). Once out you can easily change the coils from the baseplate. You may find moisture in between the plate and the coils (could be your culprit).
Good luck
Mark
Silver 1992 SE Turbo.
paza1
Postby Specky » Wed 30.01.2008, 00:41
Galsia
Can you do some photos for the Wiki please...
Cos I've got mine to do soon...
Postby Doug » Wed 30.01.2008, 08:07
i remember this was discussed before
i remember the fuel injectors being part of the discussion for when the engine seems firing on 2, as the injectors are paired . . .
not sure if it is the problem, but it is just a thought in case you need to consider that circuit too.
Postby Galsia » Wed 30.01.2008, 23:33
Galsia
Postby Specky » Wed 30.01.2008, 23:35
Galsia wrote:
Specky wrote:Galsia
Done. Just gotta resize them... :)
Cool
Postby Galsia » Thu 31.01.2008, 00:06
Galsia
Postby Specky » Thu 31.01.2008, 00:36
:clap:
:smt026
Geoff will have that on the Wiki before you know... :wink:
If not I'll do it tomorrow... (He's a slacker)
On another note, have you seperated the coils from the base plate to check for corrosion?
