Brit-Car-Nut wrote:If you meant to ask if that was the ignition switch, then, yes it is.
If you look at the non connection end, you will see that the slot for the lock portion to rotate the contacts is buggered.
That is what is causing the sticky nature of the switch.
I will look at one of the new switches I have and try to confirm the pins are in the same place.
Brit-Car-Nut wrote:Sorry, it looks to be used.
CallMeLegend wrote:Brit-Car-Nut wrote:If you meant to ask if that was the ignition switch, then, yes it is.
This is the replacement part, it's not even been fitted yet!!! I'm not 100% sure it's the correct part however.
CallMeLegend wrote:Brit-Car-Nut wrote:Sorry, it looks to be used.
Yeajh, it's the first 1-2mm look rounded off, I agree.
Brit-Car-Nut wrote:
Have you removed your original switch from the ignition housing?
Where did you get the switch you posted?
Brit-Car-Nut wrote:He just needs the switch not the lock assembly.
Brit-Car-Nut wrote:I was under the impression that the S2 has a pigtail but my UK SE column just has spades.
