by Chas54 » Wed 13.10.2021, 19:12
During the course my recent Injector swap ive done something to the service mode circuit i think.
I got locked out by the immobilzer for a few days , but now i have the engine running again, i find that when i use my dapinky switch the engine tone changes and hunts up and down , but the ECU light doesnt come on at all. It is on when the ignition switch is first turned though.
If anyone has any ideas i would be greatfull
Cgarlie
Chas54
by Simon_P » Wed 13.10.2021, 22:06
Check that the ECU plug is correctly seated.
If you still have a problem check the pin voltages in line with the EMK /EMJ manual - pages 86 and 99 come to mind.
by Chas54 » Thu 14.10.2021, 19:19
Simon
I unplugged the ECU and then re plugged it , i thought intially all was good as the ECU light on the dashboard was flashing in the service mode although the car was still hunting up and down . It wouldnt idle in normal operation though, warming had to be done with the throttle part open.
After running and trying to adjust the idle air screw, the system recorded 40000 faults - I'm guessing thats the maximum it will store.
I cleared these with a battery dissconnect, got locked out by the immoblizer again , and now when starting i get one pulse light on the ECU and also when selecting service mode i just get one blink of the light then it stays off. It has entered service mode though as i can see the IAC goes to 20 counts and the pulsating revs start..
I will check the voltage at the pins as you suggested, i think it should be 5V looking at the manual .
Also if all else fails ,i may put the old ECU back and revert to open loop . I have not tried these new ebay injectors like that yet . I'm wondering if i have a problem with injector wiring as i have disturbed it all moving it out the way when messing about with the injectors. The wiring probably suffers from the heat in the area as i think it may be brittle.
I have planned to take the immobilser off this Sunday, I have an assistant to help ring through the cables, may get the injector wiring chased at the same time.
Incidentally , its not a plug as I have pulled each lead in turn and have a corresponding drop in revs for each.
Thanks for suggestions
Charlie
Chas54
by Simon_P » Thu 14.10.2021, 20:26
Charlie,
There are lots of pins and a specific voltage for each. There are two tables for engine running /not.
by Chas54 » Fri 15.10.2021, 08:40
Thanks Simon.
I've found that, the only thing I am not sure of is if the stated voltage is plugged in or can I measure the plug pin, unplugged.
If it has to be plugged in it's a little crowded to get probe into the conductors.
Charlie
Chas54
by Chas54 » Fri 15.10.2021, 11:04
Sorry Simon
My last post a bit daft really. Now i've printed and read the plug pin chart its pretty obvious it has to be plugged in.
Just got to find something i can poke into the cable housing at the plug .
Charlie
Chas54
by Chas54 » Fri 15.10.2021, 16:34
Not quite so easy without having the ECU on jumpers . I found it virtually impossible to tell which cable i was probing . I tried a thin piece of fuse wire .
I can't see what i'm doing at the rear of the cable plugs . I can only think puncturing the insulation would allow probing but i don't like that idea much.
I took the coils off and cleaned them as i thought i may have lost some water there when tipping up the header tank to move it out the way, but no difference made . I briefly swapped back to the original ECU and set the CO pot to its mid range resistance position - still running to rough so I dont think its the new closed loop system.
But here's a funny thing i've tried. I know the vacuum on the plenum is going up and down with the engine revs ( as i most likely would) so i thought i'd use my vacuum hand pump on the MAP to set a constant vacuum. Then with a vacuum gauge connected directly to the MAP tapping point on the plenum start the engine and noted this:- The engine runs sweet and steady , the actual plenum vacuum is steady ( somewhere around 500mm Hg) . If i improve the vacuum with the hand pump the engine runs rough then cuts out at around the same vacuum.
I tried this with the petrol reg valve vacuum connection blanked off as well, so as to prove the reg isn't dumping petrol to early. It still cuts out. I have to suspect the MAP sensor but i changed it less than two years ago. I also know that on the open loop system it didn't do this.
I thing my next point is to check the voltages at the MAP under varied vacuum.
any comments appreciated
Charlie
Chas54
by Simon_P » Fri 15.10.2021, 20:42
You can remove the blue bits for better access to the bank of the pins.
by Chas54 » Sat 16.10.2021, 16:56
Simon.
Thanks for tip . its loads easier with the blue and grey pulling aids removed, I hadn't realised they came unclipped so easily.
Short piece of fuse wire held in the meters croc clip down each cable side seems to work.
Despite my earlier concern about the MAP, it seems to work as it should . with it blanked off and on the running car i could get to about 400mm Hg vacuum(0.5bar) at which point the engine stops . The voltages at the ECU pins check out Ok though . The engine runs really smooth until i reconnect everything.
The current state is its running a bit rough , but with a good vacuum about 0.35 bar .
I still dont get the flashing ECU light on the dash when entering service mode . Although i get the 12 code initially indicating entering the service mode if i have the engine stopped but ignition on.
I have no stored faults now .
I may get time tomorrow to check the rest of the pins on a warm running engine .
One thing that surprised me when looking for an earth to use on the other meter cable was that the ECU case is not connected to the earthing pins on the ECU terminals.
Thanks for advice
charlie
Chas54
by Simon_P » Sun 17.10.2021, 21:59
Do you have the ECU out of the bracket in the footwell?
I think that the case is for shielding, so connecting it to the ECU ground might be counterproductive.
How do your pin voltages compare to the maual?
by Chas54 » Mon 18.10.2021, 19:45
Simon
I think you are right , the casing is just a shield it has no connections to the motherboard-- i looked in the original closed loop ECU.
At the moment the ecu is back in the bracket and the blue/grey latching shrouds are off the plugs for the access.
I have only just finished surgically removing the Clifford alarm /immobilizer. The unit i tracked down to behind some sound proofing felt in the drivers footwell.
It was very satisfying hearing it giving it last mewing calls from the back lawn where i threw it- or at least the siren .
Now the drivers seat is out its easier to trace some of the O2 wiring i couldn't get at initially .
Ive only checked out the MAP pins so far as i thought there may be a fault with it , but it looks OK.. EMK page 3 gives some vacuum figures and corresponding output voltages and mine are pretty close.
I am checking all the pins tomorrow , It does , as you say, give figures for ignition on and for engine running but they both are done hot i think so start fresh tomorrow.
Some state B+ which if i understand right indicates the battery or charging voltage for 2 seconds so i have to catch it .
I will post my results once done.
Thanks for advice
Charlie
Chas54
by Simon_P » Tue 19.10.2021, 00:39
I took B+ to mean battery voltage at any given time.
by Chas54 » Tue 19.10.2021, 08:41
Simon
Now with a magnifying glass , I see you are quite right .
I thought it was a little odd when I read it.
Above the representation of the plug wiring it does state all B+ voltages are battery or charge system.
At the bottom there is a small star before the B+ . States that is for 2 seconds after switch on the voltage would be B+. The fuel pump time out then. My miss reading.
I also am not clear on the check engine light key in state being ".1".
I will no doubt Fing out with my probe.
Charlie
Chas54
by Chas54 » Tue 19.10.2021, 19:23
Well
. Got half of the pins probed with the engine cold and ignition on but not running.
A1-A12 and C1 to C16.
Only Variance to expected reading are C13 (TPS signal input) reading 0.45V as opposed to 0.42 max. I will have to adjust switch and recheck this one when i run the engine
Pins C3 to C6 being the IAC are stated on the chart as not valid but i measured these as C3 & C6 11.14v and C4 & C5 as 0.85 v
A5 pin ( check engine light) stated value is 0.1 my reading was 0.3v.
And lastly A8 (serial data output) I couldnt actually see the terminal to probe but by touch i got a reading of 0.45 v . It should be 5v.. I think the OY colour wire goes only to the ALDL plug and measuring there at the G pin gave 5v anyway so i think that probably i missed the pin at the ECM plug .
All other values tested OK on this side of the plug .
Back at it tomorrow . Its damned awkward to get on the pins at the ECM even with it dangling down.
Charlie
Chas54
by Chas54 » Wed 20.10.2021, 16:50
All pin voltages at ECU now checked running and cold with ignition on.
During the prodding i found the wire to D7 caused the engine to splutter about when i agitated it trying to get the piece of probe fuse wire into the back of the plug.
Further investigation found that further along the cable was a soldered connection in heat shrink that was adrift. Ive now replaced a length of this wire and i have a bit more even running.
Ive got to test again tomorrow but i think the voltage now at D7 is between 0.01v and 0.02 v
Also B9 pin is 0.05 to 1.1v but should be 0.5 Engine position input but it could have been the engine speed at the time as it was running really rough. It was at 0.4 stationary but i guess its measuring cam position.
D4 pin 1.2 to 1.54v EST output should be 1.2v
D5 pin 4.8V should be 4.5v bypass control circuit
A10 pin measured at 13.8 although should between 0 & 12 v depending on wheel position .
Still hunts about a bit in idle in service mode . But not quite so bad so ive managed to adjust the Idle control screw .
Running at around 0.5% CO.
I will have to put the car back together tomorrow - seats are out and panel off in the hood compartment after removing the Clifford., recheck the voltage at some of the pins on the ECU and give it a run.
Charlie
Chas54
by Steve A » Wed 20.10.2021, 23:49
I don't envy your task, I hope your meticulous work pays off
by Chas54 » Thu 21.10.2021, 12:57
I am struggling to make sense of the O2 sensor internals.
I've checked the D7 pin voltage and its far to low with the engine hot and running. 0.02 ,0.01.
Ringing the wires through from the ECM to the wing socket the cables check out OK .. Black is D6 earth, grey is D7 O2 sensor signal return , brown coloured is the ignition warning light 12v supply . All are good.
On the O2 sensor cable is a 4pin socket with 3 used pins. The cable colours are 2 whites and one black. when plugged in the black cable goes into the grey wing cable.. This is the way it came wired.
None of the three cables coming out of the O2 sensor are connected to the outer metal of the O2 sensor . This seems a little odd to me.
The diagram EMJ.4-7 ECM wiring shows the two circuits within the O2 sensor.
So I've made the assumption that the 2 whites are the heating connections and the black is the variable resistor to D7. When measuring to the engine block and the black cable i find its open circuit, i sure i should be able to measure some resistance. Its not connected to the heating earth cable either .
Is this correct ??
Any advice welcome
Chas54
by Chas54 » Thu 21.10.2021, 13:02
Steve,
Its not as bad as it sounds . Simon P pointed out to me that if you remove the plastic clipping in bits from the ECM plugs you could in fact slip something in there to measure the voltages.
With the ECM unmounted you can turn it over to reach the other side row of pins . I use a piece of thick fuse wire held in the croc clip of the meter.
charlie
Chas54
by RonR » Thu 21.10.2021, 15:10
Chas,
I just checked my brand new Bosch 15701 O2 sensor, freshly delivered from RockAuto:
There's 3.5 ohms between the two white wires - by my reckoning that's a heater power of around 45 watts.
My black wire is like yours, no connection to the outer casing or the white wires, at least when cold.
by Chas54 » Thu 21.10.2021, 16:48
Thanks Ron
Sounds as if mine is OK.
Chas54
