Hi Rich. Mine's a Dec '90 SE (previously) w/out a complete loom .This black 3 wire black/brown-yellow/grey-green is the connector that I needed to connect my new O2 sensor to - and you can
just manage to make out the brown-yellow + grey-green wires on your pic; the black wire is well-camouflaged by your paintwork
. I didn't feel the need to find out anything about that other grey m/plug connector at the time, though...
I'd be very surprised if your Feb '92 Elan didn't have the complete loom already. I'd have normally thought that with this reg date, yours must either be one of the very last SEs or an early S2 (which would already have been 1499'd c/w O2 sensor and cat fitted...)
Out of interest:- 1. I presume you've ElanScanned your ecu to verify your current promid? (I'd imagine 9929/9930...)
and 2. have you already '1499'd' your ecu? (- or where will you get the memcal upgrade from?)
Finally, imo you'll be glad you 'bit the bullet'. Upgrading to closed loop has vastly improved my fuel cons (easily 35mpg local + ~45 on a run with a light foot) and freed me from impending emission worries around MoT time.
Let us know how it goes. I took loadsa pics and would be more than happy to share them, if it helps. (You're not alone
and don't forget to soak that O2/turbo blank for a week or two, get access to a long breaker bar
) and a pal to hold the socket down as you strain to break the infamous 'welded rust bond'. Previous heating, then dousing it with ice has been suggested too...)
dur...I've just found your earlier post where you wanted to upgrade from 9929 to 9930 and presume that you've decided to 'step further' to 1499. RonR was a major source of motivation and inspiration along with valuable input from other 'stars'. Without that much-needed advice and encouragement mine definitely wouldn't have happened!
