by Doug » Thu 09.03.2006, 22:46
just wanted to interject that this seems like a hefty price for what? do these plugs really have any advantage over the dirt cheap and good regular ones?? You should be able to get regular plugs for one-tenth that price you are quoting . . .
here's the pic from Costas and even he is still using stock plugs (I'd think he could get some advantage to changing to a colder plug, but that's another thread)
- LEC Founder
by ailwyn » Thu 09.03.2006, 23:41
At £25 it's about double the cost of standard plugs.
I don't think the heat rating has changed, only the tip material (someone correct me if I've got that wrong).
If I understood ESMs previous posts they provide a more reliable spark, or in other words less prone to missfires.
As the Elan is my only available car I would rather pay the extra for peace of mind (missplaced or not) and reading up on the problems experienced by some which these plugs have cured then that's endorsement enough for me.
Ailwyn
- Forum Member
by ailwyn » Thu 09.03.2006, 23:43
Just received this email reply:
Hi Ailwyn,
Best rate we can do is £25 per set and we will give this to you on an ongoing basis until there is a price reveiw from NGK later in the year.
Our shop is based at APD LTD, UNIT 2 ASH, KEMBREY PARK, SWINDON,SN2 8UN.
Phone number is 01793 433 933 and we accept credit card on the phone.
I hope this helps.
We will set up a quote reference LEC701 for potential customers to ring if they are phoning if this helps
Just e-mail me back if you have any other questions.
Of course we sell all part for cars--oils,wipers,brakes,clutch etc....
We also sell sat nav,stereos etc...
Kind Regards
Fraser
- Forum Member
by Doug » Fri 10.03.2006, 00:16
well I can get 4 BKR6E plugs for $6 just FYI, this is 7-8 times less than your £25
you can get them I am just butting in to be sure people aren't expecting much from the costly ones
I'll sell ya 4 BKR6Es for £20 if ya like . . . a deal . . .
- LEC Founder
by ailwyn » Fri 10.03.2006, 08:57
Doug wrote:I'll sell ya 4 BKR6Es for £20 if ya like . . . a deal . . .
Make them iridium tipped and you have a deal
Ailwyn
- Forum Member
by Monty » Mon 16.04.2007, 23:31
Who went for the BKR6EIX spark plug that Alan was recomending and have u noticed any difference in performance etc? as i`m doing a full service and going to need a set of plugs.
www.spark-plugs.co.uk/index.htm are doing a set for less than £28 including postage
The BKR6E are less than £12 for a set
- Chunder King!
by ailwyn » Tue 17.04.2007, 10:29
Monty,
I've bought them but have not gotten around to fitting them yet.... it's next on my list once the brakes are done.
A.
- Forum Member
by Gazza » Tue 17.04.2007, 13:06
I have recently fitted them with the King######? HT leads and can't really say I notice any difference.
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
by ailwyn » Tue 17.04.2007, 15:55
Unless you are suffering misfire under boost I doubt you will see much improvement.
My hope is a more reliable spark will result in a better burn of fuel which should then result in (slightly) better fuel efficiency, but I won't be surprised if I see no tangible benefit.
A.
- Forum Member
by Monty » Tue 17.04.2007, 19:31
Thanks for u`r replys,
Since i do trackdays i might give them a try.
Jay
- Chunder King!
by Monty » Sat 28.04.2007, 22:31
Monty wrote:Who went for the BKR6EIX spark plug that Alan was recomending and have u noticed any difference in performance etc? as i'm doing a full service and going to need a set of plugs.
Got the above sprakplugs today and have them fitted torqued to 27Nm, was quite supprised how small/fine the Iridium tip is compared to the standard BKR6E
- Chunder King!
by GeoffSmith » Sun 29.04.2007, 10:35
Monty wrote:was quite supprised how small/fine the Iridium tip is compared to the standard BKR6E
Yep. Iridium is
good stuff and pretty rare!
- Kitty Fiddler
by Paul.P » Sun 29.04.2007, 11:03
Also believe these come pre gapped & that they don't recomend you try to alter it as it will break the tip !
by Monty » Sun 29.04.2007, 13:52
Paul.P wrote:Also believe these come pre gapped & that they don't recomend you try to alter it as it will break the tip !
well the 0.8mm feeler gauge was tight so i did squeeze it in to make sure the gap was right
but not all cars have the same gap ie N/A and turbo so in that case they will need re gapping
- Chunder King!
by Specky » Sun 29.04.2007, 14:26
They put them in tester first to confirm they have the optimum spark...
Well I say tester... Its a box with a little window and a 45 degree mirror so you can see whats happening...
There's got to be one on the internet... I'll have a search..
Edit..Sort of like this, but they have a thermo couple in the "test spark plugs"
Your plugs should be gapped for the the higest compression and hottest temperature heat a plug can take... Pre set by the Manufacturer
I'm not gonna guess, but does the N/A use the same plugs... ours would have some thing like a a 6 in the part No.. there's might be a 7..
Just a guess on Numbers... so I'm not reponsible..
by Russc » Mon 04.06.2007, 15:26
Monty, where did you get them from? any difference?
I`m getting the misfire on boost so am going to try a change of plugs first.
DOh!!! ignore me link is in his post !
Russc
by Monty » Mon 04.06.2007, 16:47
LMAO
can`t say i`ve noticed a difference myself but got to be worth a try if u`r getting a misfire
- Chunder King!
by davel » Tue 19.06.2007, 14:03
I have just purchased a set of BPR6EIX-11 , to try and cure a misfire under boost . They will not fit into the hole, and fit a socket on the plug, theBPR6EIX-11 are 20mm across the flat and the original 16mm Has anyone had this problem.
thanks
davel
by Gazza » Tue 19.06.2007, 14:29
I think they should be BKR's not BPR's, I had no problems
SOLD
Gazza
Users browsing this forum: No registered users and 14 guests
