ignition key
ignition key
Postby LXADO63 » Fri 06.07.2007, 14:43
my ignition key is stuck in the ignition and will not come out. The turns and operates normally for every position except the position where the key is removed from- stops about 1/8" from that position. Has anyone experienced the problem? (I have tried wiggling the wheel, rolling the car forward and back, starting it up again, wd40, etc)
LXADO63
