Enright on 26/4/07 wrote:I had my car MOT'd this week in Elysium mode using the O2 sensor.
The result was that CO emissions had dropped from 2.88% last year to 0.68% (the pass limit is 3.5%), and HC's had dropped from 134ppm to 103ppm (the pass limit is 3500), indicating a much more efficient state of tune.
This backs up my own observations in fuel economy.
In fact it almost passed the catalytic converter test, even though I don't have one fitted!
duncan wrote:Hi Neil,
I like the idea of using an S2 chip rather than finding an ECU for EU turdo with CAT. My only concern is if it will work with the existing ECU (1990-1) and if the wiring etc is the same. Do I need to also use the ESM's V5 Switcher Module.
The C02 is at 2.9% and it needs to be 4% The o2 is .88 v and in open loop. I am also told I have an EGK valve what ever that is![]()
This is hard enough in English let alone trying to get this sorted in another country. Just dont want to get taken for a ride so appreciate the help![]()
Dunc
one more question
will the regular 02 sens work ok or do I need a BroardBand version?
thanks
Dunc
duncan wrote:sounds like all I need to do is find ESM and find out how to install it all.
surferphil wrote:My Standard SE Failed the MOT Test on emissions. The lotus dealership who services my cars sent the EEPROM back to lotus and they sent a replacement for about £12. It passed and the world is now a safer place. Put a CAT on and you would probably reduce the performance.
ailwyn wrote:surferphil wrote:My Standard SE Failed the MOT Test on emissions. The lotus dealership who services my cars sent the EEPROM back to lotus and they sent a replacement for about £12. It passed and the world is now a safer place. Put a CAT on and you would probably reduce the performance.
I bet the lotus chip doesn't drop the emissions by 90% though.
In the UK, SE's have a CO target of 3.0% (no-CAT) and S2s 0.3%, hence needing the CAT.
Now if you could get (in the UK) an MOT tester that wasn't "aware" that there was supposed to be a CAT on the S2, you could get it tested against 3.0% and therefore CAT or no CAT it would be likely to pass, unfortunately my mechanic is too clued up
