Mods, might add this to Wiki coil write-up
Postby tweetdriver63 » Mon 11.08.2008, 17:36
I just replaced my plugs, leads, and coil packs. MSD coil packs, NGK plugs, and performance leads with firebraid from Robie the Robot.
Here's what might be good to add to that Wiki write-up:
It's possible, and very easy, to replace the coil packs without taking the whole coil assembly out, like is described in the Wiki. The two coil packs are held to the bracket via two 7/32 inch bolts. The black plastic base of the assembly, that contains the wiring, is held on by those same bolts, by compression. There's apparently a grommet or insulator in the holes in the plastic base, because the bolts don't fall out when you loosen them, which is nice. Leave the three wiring harness connectors connected, and the wiring base will pretty much stay where it is when you remove the coil packs. There's a couple of built-in studs on the base that go into holes in the bracket to line it up so it all goes back together easily.
I used a short ratchet handle, with a 4 inch extension to easily reach the bolts and have room to turn the handle.
When replacing the coil packs, I'm betting it's easier to handle them individually, than it is to remove the whole assembly. The entire job (plugs, leads, and coil packs) took only about 30 minutes.
sorry I didn't take any pictures, but using the ones in the existing Wiki write-up should be good enough. Locating the bolts that hold the packs to the bracket is also easy. Just look at your new packs to see where the bolts are. The two top bolts can be seen. The two lower ones you have to feel for.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Postby GeoffSmith » Sat 16.08.2008, 19:51
Chris, thanks for the information. I've updated the Wiki and added some additional information here.
Please do not consider the Wiki as the sole preserve of the admin/mods however. Mere mortals (why, even I am allowed to play:twisted:) are encouraged to register and make additions and changes. It eases the burden on the few who traditionally tried to capture all the useful information. Don't worry about cocking anything up either - it's quite easy once you get the hang of it, it's backed up regularly and there is always someone who can help to tidy it up or sort out problems.
Geoff
Re: Mods, might add this to Wiki coil write-up
Postby nitroman » Thu 30.07.2009, 06:04
Coil, various manufacturers/resellers & their part number:
AC Delco D555 / E530C
AIRTEX 5C1058
Autoparts4America TGO-44-65
BECK/ARNLEY 1788179
BWD Automotive E51
Carquest DR-39 / DR-39X / 52-1924
Kem Parts 342J
WELLS C849
List of vehicles using the same Ignition Coil (as the Elan):
BUICK CENTURY 2004 V6-189ci 3.1L F/I Vin J
BUICK CENTURY 2003 V6-189ci 3.1L F/I Vin J
BUICK CENTURY 2002 V6-189ci 3.1L F/I Vin J
BUICK CENTURY 2001 V6-189ci 3.1L F/I Vin J
BUICK CENTURY 2000 V6-189ci 3.1L F/I Vin J
BUICK CENTURY 1999 V6-189ci 3.1L F/I Vin M
BUICK CENTURY 1998 V6-189ci 3.1L F/I Vin M
BUICK CENTURY 1997 V6-189ci 3.1L F/I Vin M
BUICK CENTURY 1996 L4-134ci 2.2L F/I Vin 4
BUICK CENTURY 1996 V6-189ci 3.1L F/I Vin M
BUICK CENTURY 1995 L4-134ci 2.2L F/I Vin 4
BUICK CENTURY 1995 V6-189ci 3.1L F/I Vin M
BUICK CENTURY 1994 L4-134ci 2.2L F/I Vin 4
BUICK CENTURY 1994 V6-189ci 3.1L F/I Vin M
BUICK CENTURY 1993 L4-134ci 2.2L F/I Vin 4
BUICK CENTURY 1993 V6-204ci 3.3L F/I Vin N
BUICK CENTURY 1992 L4-151ci 2.5L F/I Vin R
BUICK CENTURY 1992 V6-204ci 3.3L F/I Vin N
BUICK CENTURY 1991 L4-151ci 2.5L F/I Vin R
BUICK CENTURY 1991 V6-204ci 3.3L F/I Vin N
BUICK CENTURY 1990 L4-151ci 2.5L F/I Vin R
BUICK CENTURY 1990 V6-204ci 3.3L F/I Vin N
BUICK CENTURY 1989 L4-151ci 2.5L F/I Vin R
BUICK CENTURY 1989 V6-173ci 2.8L F/I Vin W
BUICK CENTURY 1989 V6-204ci 3.3L F/I Vin N
BUICK CENTURY 1988 L4-151ci 2.5L F/I Vin R
BUICK CENTURY 1988 V6-173ci 2.8L F/I Vin W
BUICK CENTURY 1988 V6-231ci 3.8L F/I Vin 3
BUICK CENTURY 1987 L4-151ci 2.5L F/I Vin R
BUICK CENTURY 1987 V6-173ci 2.8L F/I Vin W
BUICK CENTURY 1987 V6-231ci 3.8L F/I Vin 3
BUICK CENTURY 1986 V6-231ci 3.8L F/I Vin 3
BUICK ELECTRA 1987 V6-231ci 3.8L F/I Vin 3
BUICK ELECTRA 1986 V6-231ci 3.8L F/I Vin B
BUICK LACROSSE 2007 V6-231ci 3.8L F/I Vin 2
BUICK LACROSSE 2006 V6-231ci 3.8L F/I Vin 2
BUICK LACROSSE 2005 V6-231ci 3.8L F/I Vin 2
BUICK LESABRE 2005 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 2004 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 2003 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 2002 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 2001 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 2000 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 1999 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 1998 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 1997 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 1996 V6-231ci 3.8L F/I Vin K
BUICK LESABRE 1995 V6-231ci 3.8L F/I Vin L
BUICK LESABRE 1994 V6-231ci 3.8L F/I Vin L
BUICK LESABRE 1993 V6-231ci 3.8L F/I Vin L
BUICK LESABRE 1992 V6-231ci 3.8L F/I Vin L
BUICK LESABRE 1988 V6-231ci 3.8L F/I Vin 3
BUICK LESABRE 1987 V6-231ci 3.8L F/I Vin 3
BUICK LESABRE 1986 V6-231ci 3.8L F/I Vin 3
BUICK LUCERNE 2007 V6-231ci 3.8L F/I Vin 2
BUICK LUCERNE 2006 V6-231ci 3.8L F/I Vin 2
BUICK PARK AVENUE 2005 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 2004 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 2003 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 2002 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 2001 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE 2001 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 2000 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 1999 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK PARK AVENUE 1999 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 1998 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 1997 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 1996 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 1995 V6-231ci 3.8L F/I Vin K
BUICK PARK AVENUE 1994 V6-231ci 3.8L F/I Vin L
BUICK PARK AVENUE 1993 V6-231ci 3.8L F/I Vin L
BUICK PARK AVENUE 1992 V6-231ci 3.8L F/I Vin L
BUICK PARK AVENUE ULTRA 2005 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 2004 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 2003 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 2002 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 2000 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1998 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1997 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1996 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1995 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1994 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1993 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1992 V6-231ci 3.8L F/I Supercharged Vin 1 (ULTRA)
BUICK PARK AVENUE ULTRA 1991 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK REATTA 1991 V6-231ci 3.8L F/I Vin L
BUICK REGAL 2004 V6-231ci 3.8L F/I Supercharged Vin 1 (GS)
BUICK REGAL 2004 V6-231ci 3.8L F/I Vin K (LS)
BUICK REGAL 2003 V6-231ci 3.8L F/I Supercharged Vin 1 (GS)
BUICK REGAL 2003 V6-231ci 3.8L F/I Vin K (LS)
BUICK REGAL 2002 V6-231ci 3.8L F/I Supercharged Vin 1 (GS)
BUICK REGAL 2002 V6-231ci 3.8L F/I Vin K (LS)
BUICK REGAL 2001 V6-231ci 3.8L F/I Supercharged Vin 1 (GS)
BUICK REGAL 2001 V6-231ci 3.8L F/I Vin K (LS)
BUICK REGAL 2000 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK REGAL 2000 V6-231ci 3.8L F/I Vin K
BUICK REGAL 1999 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK REGAL 1999 V6-231ci 3.8L F/I Vin K
BUICK REGAL 1998 V6-231ci 3.8L F/I Vin K (LS)
BUICK REGAL 1997 V6-231ci 3.8L F/I Supercharged Vin 1 (GS)
BUICK REGAL 1997 V6-231ci 3.8L F/I Vin K (LS)
BUICK REGAL 1996 V6-189ci 3.1L F/I Vin M
BUICK REGAL 1996 V6-231ci 3.8L F/I Vin K
BUICK REGAL 1995 V6-189ci 3.1L F/I Vin M
BUICK REGAL 1995 V6-231ci 3.8L F/I Vin L
BUICK REGAL 1994 V6-189ci 3.1L F/I Vin M
BUICK REGAL 1994 V6-231ci 3.8L F/I Vin L
BUICK REGAL 1993 V6-189ci 3.1L F/I Vin T
BUICK REGAL 1993 V6-231ci 3.8L F/I Vin L
BUICK REGAL 1992 V6-189ci 3.1L F/I Vin T
BUICK REGAL 1992 V6-231ci 3.8L F/I Vin L
BUICK REGAL 1991 V6-189ci 3.1L F/I Vin T
BUICK REGAL 1991 V6-231ci 3.8L F/I Vin L
BUICK REGAL 1990 V6-189ci 3.1L F/I Vin T
BUICK REGAL 1990 V6-231ci 3.8L F/I Vin L
BUICK REGAL 1989 V6-173ci 2.8L F/I Vin W
BUICK REGAL 1989 V6-189ci 3.1L F/I Vin T
BUICK REGAL 1988 V6-173ci 2.8L F/I Vin W
BUICK REGAL GS 1998 V6-231ci 3.8L F/I Supercharged Vin 1 (GS)
BUICK RENDEZVOUS 2005 V6-207ci 3.4L F/I Vin E
BUICK RENDEZVOUS 2004 V6-207ci 3.4L F/I Vin E
BUICK RENDEZVOUS 2003 V6-207ci 3.4L F/I Vin E
BUICK RENDEZVOUS 2002 V6-207ci 3.4L F/I Vin E
BUICK RIVIERA 1999 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK RIVIERA 1998 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK RIVIERA 1997 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK RIVIERA 1997 V6-231ci 3.8L F/I Vin K
BUICK RIVIERA 1996 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK RIVIERA 1996 V6-231ci 3.8L F/I Vin K
BUICK RIVIERA 1995 V6-231ci 3.8L F/I Supercharged Vin 1
BUICK RIVIERA 1995 V6-231ci 3.8L F/I Vin K
BUICK RIVIERA 1993 V6-231ci 3.8L F/I Vin L
BUICK RIVIERA 1992 V6-231ci 3.8L F/I Vin L
BUICK RIVIERA 1991 V6-231ci 3.8L F/I Vin L
BUICK RIVIERA 1987 V6-231ci 3.8L F/I Vin 3
BUICK RIVIERA 1986 V6-231ci 3.8L F/I Vin B
BUICK SKYHAWK 1989 L4-122ci 2.0L F/I Vin 1
BUICK SKYHAWK 1988 L4-122ci 2.0L F/I Vin 1
BUICK SKYHAWK 1987 L4-122ci 2.0L F/I Vin 1
BUICK SKYLARK 1998 V6-189ci 3.1L F/I Vin M
BUICK SKYLARK 1997 V6-189ci 3.1L F/I Vin M
BUICK SKYLARK 1996 V6-189ci 3.1L F/I Vin M
BUICK SKYLARK 1995 V6-189ci 3.1L F/I Vin M
BUICK SKYLARK 1994 V6-189ci 3.1L F/I Vin M
BUICK SKYLARK 1993 V6-204ci 3.3L F/I Vin N
BUICK SKYLARK 1992 V6-204ci 3.3L F/I Vin N
BUICK SKYLARK 1991 L4-151ci 2.5L F/I Vin U
BUICK SKYLARK 1991 V6-204ci 3.3L F/I Vin N
BUICK SKYLARK 1990 L4-151ci 2.5L F/I Vin U
BUICK SKYLARK 1990 V6-204ci 3.3L F/I Vin N
BUICK SKYLARK 1989 L4-151ci 2.5L F/I Vin U
BUICK SKYLARK 1989 V6-204ci 3.3L F/I Vin N
BUICK SKYLARK 1988 L4-151ci 2.5L F/I Vin U
BUICK SKYLARK 1987 L4-151ci 2.5L F/I Vin U
BUICK SOMERSET 1987 L4-151ci 2.5L F/I Vin U
CADILLAC ALLANTE 1993 V8-281ci 4.6L F/I Vin 9
CADILLAC CIMARRON 1988 V6-173ci 2.8L F/I Vin W
CADILLAC CIMARRON 1987 V6-173ci 2.8L F/I Vin W
CADILLAC DEVILLE 1999 V8-281ci 4.6L F/I Vin Y
CADILLAC DEVILLE 1998 V8-281ci 4.6L F/I Vin Y
CADILLAC DEVILLE 1997 V8-281ci 4.6L F/I Vin Y
CADILLAC DEVILLE 1996 V8-281ci 4.6L F/I Vin Y
CADILLAC DEVILLE CONCOURS 1999 V8-281ci 4.6L F/I Vin 9
CADILLAC DEVILLE CONCOURS 1998 V8-281ci 4.6L F/I Vin 9
CADILLAC DEVILLE CONCOURS 1997 V8-281ci 4.6L F/I Vin 9
CADILLAC DEVILLE CONCOURS 1996 V8-281ci 4.6L F/I Vin 9
CADILLAC DEVILLE CONCOURS 1995 V8-281ci 4.6L F/I Vin Y
CADILLAC DEVILLE CONCOURS 1994 V8-281ci 4.6L F/I Vin Y
CADILLAC ELDORADO 1999 V8-281ci 4.6L F/I Vin 9
CADILLAC ELDORADO 1999 V8-281ci 4.6L F/I Vin Y
CADILLAC ELDORADO 1998 V8-281ci 4.6L F/I Vin Y (ELC)
CADILLAC ELDORADO 1997 V8-281ci 4.6L F/I Vin Y
CADILLAC ELDORADO 1996 V8-281ci 4.6L F/I Vin 9 (TOURING)
CADILLAC ELDORADO 1996 V8-281ci 4.6L F/I Vin Y
CADILLAC ELDORADO 1995 V8-281ci 4.6L F/I Vin 9 (TOURING)
CADILLAC ELDORADO 1995 V8-281ci 4.6L F/I Vin Y
CADILLAC ELDORADO 1994 V8-281ci 4.6L F/I Vin 9 (TOURING)
CADILLAC ELDORADO 1994 V8-281ci 4.6L F/I Vin Y
CADILLAC ELDORADO SPORT COUPE 1993 V8-281ci 4.6L F/I Vin Y (SPORT)
CADILLAC ELDORADO TOURING COUPE 1998 V8-281ci 4.6L F/I Vin 9 (ETC)
CADILLAC ELDORADO TOURING COUPE 1997 V8-281ci 4.6L F/I Vin 9 (TOURING)
CADILLAC ELDORADO TOURING COUPE 1993 V8-281ci 4.6L F/I Vin 9 (TOURING)
CADILLAC SEVILLE 1999 V8-281ci 4.6L F/I Vin 9
CADILLAC SEVILLE 1999 V8-281ci 4.6L F/I Vin Y
CADILLAC SEVILLE SLS 1998 V8-281ci 4.6L F/I Vin Y (SLS)
CADILLAC SEVILLE SLS 1997 V8-281ci 4.6L F/I Vin Y (SLS)
CADILLAC SEVILLE SLS 1996 V8-281ci 4.6L F/I Vin Y (SLS)
CADILLAC SEVILLE SLS 1995 V8-281ci 4.6L F/I Vin Y (SLS)
CADILLAC SEVILLE SLS 1994 V8-281ci 4.6L F/I Vin Y (SLS)
CADILLAC SEVILLE STS 1998 V8-281ci 4.6L F/I Vin 9 (STS)
CADILLAC SEVILLE STS 1997 V8-281ci 4.6L F/I Vin 9 (STS)
CADILLAC SEVILLE STS 1996 V8-281ci 4.6L F/I Vin 9 (STS)
CADILLAC SEVILLE STS 1995 V8-281ci 4.6L F/I Vin 9 (STS)
CADILLAC SEVILLE STS 1994 V8-281ci 4.6L F/I Vin 9 (STS)
CADILLAC SEVILLE STS 1993 V8-281ci 4.6L F/I Vin 9 (STS)
CHEVROLET BERETTA 1996 L4-133ci 2.2L F/I Vin 4
CHEVROLET BERETTA 1996 V6-189ci 3.1L F/I Vin M
CHEVROLET BERETTA 1995 L4-133ci 2.2L F/I Vin 4
CHEVROLET BERETTA 1995 V6-189ci 3.1L F/I Vin M
CHEVROLET BERETTA 1994 L4-133ci 2.2L F/I Vin 4
CHEVROLET BERETTA 1994 V6-189ci 3.1L F/I Vin M
CHEVROLET BERETTA 1993 L4-133ci 2.2L F/I Vin 4
CHEVROLET BERETTA 1993 V6-189ci 3.1L F/I Vin T
CHEVROLET BERETTA 1992 L4-133ci 2.2L F/I Vin 4
CHEVROLET BERETTA 1992 V6-189ci 3.1L F/I Vin T
CHEVROLET BERETTA 1991 L4-133ci 2.2L F/I Vin G
CHEVROLET BERETTA 1991 V6-189ci 3.1L F/I Vin T
CHEVROLET BERETTA 1990 L4-133ci 2.2L F/I Vin G
CHEVROLET BERETTA 1990 V6-189ci 3.1L F/I Vin T
CHEVROLET BERETTA 1989 L4-121ci 2.0L F/I Vin 1
CHEVROLET BERETTA 1989 V6-173ci 2.8L F/I Vin W
CHEVROLET BERETTA 1988 L4-121ci 2.0L F/I Vin 1
CHEVROLET BERETTA 1988 V6-173ci 2.8L F/I Vin W
CHEVROLET BERETTA 1987 L4-121ci 2.0L F/I Vin 1
CHEVROLET BERETTA 1987 V6-173ci 2.8L F/I Vin W
CHEVROLET CAMARO 2002 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 2001 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 2000 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 1999 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 1998 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 1997 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 1996 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 1995 V6-207ci 3.4L F/I Vin S
CHEVROLET CAMARO 1995 V6-231ci 3.8L F/I Vin K
CHEVROLET CAMARO 1994 V6-207ci 3.4L F/I Vin S
CHEVROLET CAMARO RS 1993 V6-207ci 3.4L F/I Vin S
CHEVROLET CAVALIER 2002 L4-134ci 2.2L BIFUEL/FI Vin 4
CHEVROLET CAVALIER 2002 L4-134ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 2001 L4-134ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 2000 L4-134ci 2.2L BIFUEL/FI Vin 4
CHEVROLET CAVALIER 2000 L4-134ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1999 L4-134ci 2.2L BIFUEL/FI Vin 4
CHEVROLET CAVALIER 1999 L4-134ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1998 L4-134ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1997 L4-133ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1996 L4-133ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1995 L4-133ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1994 L4-133ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1994 V6-189ci 3.1L F/I Vin T
CHEVROLET CAVALIER 1993 L4-133ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1993 V6-189ci 3.1L F/I Vin T
CHEVROLET CAVALIER 1992 L4-133ci 2.2L F/I Vin 4
CHEVROLET CAVALIER 1992 V6-189ci 3.1L F/I Vin T
CHEVROLET CAVALIER 1991 L4-133ci 2.2L F/I Vin G
CHEVROLET CAVALIER 1991 V6-189ci 3.1L F/I Vin T
CHEVROLET CAVALIER 1990 L4-133ci 2.2L F/I Vin G
CHEVROLET CAVALIER 1990 V6-189ci 3.1L F/I Vin T
CHEVROLET CAVALIER 1989 L4-121ci 2.0L F/I Vin 1
CHEVROLET CAVALIER 1989 V6-173ci 2.8L F/I Vin W
CHEVROLET CAVALIER 1988 L4-121ci 2.0L F/I Vin 1
CHEVROLET CAVALIER 1988 V6-173ci 2.8L F/I Vin W
CHEVROLET CAVALIER 1987 L4-121ci 2.0L F/I Vin 1
CHEVROLET CAVALIER 1987 V6-173ci 2.8L F/I Vin W
CHEVROLET CELEBRITY 1990 L4-151ci 2.5L F/I Vin R
CHEVROLET CELEBRITY 1990 V6-189ci 3.1L F/I Vin T
CHEVROLET CELEBRITY 1989 L4-151ci 2.5L F/I Vin R
CHEVROLET CELEBRITY 1989 V6-173ci 2.8L F/I Vin W
CHEVROLET CELEBRITY 1988 L4-151ci 2.5L F/I Vin R
CHEVROLET CELEBRITY 1988 V6-173ci 2.8L F/I Vin W
CHEVROLET CELEBRITY 1987 L4-151ci 2.5L F/I Vin R
CHEVROLET CELEBRITY 1987 V6-173ci 2.8L F/I Vin W
CHEVROLET CORSICA 1996 L4-133ci 2.2L F/I Vin 4
CHEVROLET CORSICA 1996 V6-189ci 3.1L F/I Vin M
CHEVROLET CORSICA 1995 L4-133ci 2.2L F/I Vin 4
CHEVROLET CORSICA 1995 V6-189ci 3.1L F/I Vin M
CHEVROLET CORSICA 1994 L4-133ci 2.2L F/I Vin 4
CHEVROLET CORSICA 1994 V6-189ci 3.1L F/I Vin M
CHEVROLET CORSICA 1993 L4-133ci 2.2L F/I Vin 4
CHEVROLET CORSICA 1993 V6-189ci 3.1L F/I Vin T
CHEVROLET CORSICA 1992 L4-133ci 2.2L F/I Vin 4
CHEVROLET CORSICA 1992 V6-189ci 3.1L F/I Vin T
CHEVROLET CORSICA 1991 L4-133ci 2.2L F/I Vin G
CHEVROLET CORSICA 1991 V6-189ci 3.1L F/I Vin T
CHEVROLET CORSICA 1990 L4-133ci 2.2L F/I Vin G
CHEVROLET CORSICA 1990 V6-189ci 3.1L F/I Vin T
CHEVROLET CORSICA 1989 L4-121ci 2.0L F/I Vin 1
CHEVROLET CORSICA 1989 V6-173ci 2.8L F/I Vin W
CHEVROLET CORSICA 1988 L4-121ci 2.0L F/I Vin 1
CHEVROLET CORSICA 1988 V6-173ci 2.8L F/I Vin W
CHEVROLET CORSICA 1987 L4-121ci 2.0L F/I Vin 1
CHEVROLET CORSICA 1987 V6-173ci 2.8L F/I Vin W
CHEVROLET CORVETTE ZR1 1995 V8-350ci 5.7L F/I Vin J (ZR1)
CHEVROLET CORVETTE ZR1 1994 V8-350ci 5.7L F/I Vin J (ZR1)
CHEVROLET CORVETTE ZR1 1993 V8-350ci 5.7L F/I Vin J (ZR1)
CHEVROLET CORVETTE ZR1 1992 V8-350ci 5.7L F/I Vin J (ZR1)
CHEVROLET CORVETTE ZR1 1991 V8-350ci 5.7L F/I Vin J (ZR1)
CHEVROLET CORVETTE ZR1 1990 V8-350ci 5.7L F/I Vin J (ZR1)
CHEVROLET IMPALA 2005 V6-207ci 3.4L F/I Vin E
CHEVROLET IMPALA 2005 V6-231ci 3.8L F/I Vin K
CHEVROLET IMPALA 2004 V6-207ci 3.4L F/I Vin E
CHEVROLET IMPALA 2004 V6-231ci 3.8L F/I Vin K
CHEVROLET IMPALA 2003 V6-207ci 3.4L F/I Vin E
CHEVROLET IMPALA 2003 V6-231ci 3.8L F/I Vin K
CHEVROLET IMPALA 2002 V6-207ci 3.4L F/I Vin E
CHEVROLET IMPALA 2002 V6-231ci 3.8L F/I Vin K
CHEVROLET IMPALA 2001 V6-207ci 3.4L F/I Vin E
CHEVROLET IMPALA 2001 V6-231ci 3.8L F/I Vin K
CHEVROLET IMPALA 2000 V6-207ci 3.4L F/I Vin E
CHEVROLET IMPALA 2000 V6-231ci 3.8L F/I Vin K
CHEVROLET IMPALA SS 2005 V6-231ci 3.8L F/I Supercharged Vin 1 (SS)
CHEVROLET IMPALA SS 2004 V6-231ci 3.8L F/I Supercharged Vin 1 (SS)
CHEVROLET LLV [POSTAL VEHICLE] 1995 L4-134ci 2.2L F/I Vin 4
CHEVROLET LLV [POSTAL VEHICLE] 1994 L4-134ci 2.2L F/I Vin 4
CHEVROLET LUMINA 2001 V6-189ci 3.1L F/I Vin J
CHEVROLET LUMINA 2000 V6-189ci 3.1L F/I Vin J
CHEVROLET LUMINA 1999 V6-189ci 3.1L F/I Vin M
CHEVROLET LUMINA 1999 V6-231ci 3.8L F/I Vin K
CHEVROLET LUMINA 1998 V6-189ci 3.1L F/I Vin M
CHEVROLET LUMINA 1997 V6-189ci 3.1L F/I Vin M
CHEVROLET LUMINA 1997 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA 1996 V6-189ci 3.1L F/I Vin M
CHEVROLET LUMINA 1996 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA 1995 V6-189ci 3.1L F/I Vin M
CHEVROLET LUMINA 1995 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA 1994 V6-189ci 3.1L F/I Vin T
CHEVROLET LUMINA 1993 V6-189ci 3.1L F/I Vin T
CHEVROLET LUMINA 1992 L4-151ci 2.5L F/I Vin R
CHEVROLET LUMINA 1992 V6-189ci 3.1L F/I Vin T
CHEVROLET LUMINA 1991 L4-151ci 2.5L F/I Vin R
CHEVROLET LUMINA 1991 V6-189ci 3.1L F/I Vin T
CHEVROLET LUMINA 1990 L4-151ci 2.5L F/I Vin R
CHEVROLET LUMINA 1990 V6-189ci 3.1L F/I Vin T
CHEVROLET LUMINA APV 1996 V6-207ci 3.4L F/I Vin E
CHEVROLET LUMINA APV 1995 V6-231ci 3.8L F/I Vin L
CHEVROLET LUMINA APV 1994 V6-231ci 3.8L F/I Vin L
CHEVROLET LUMINA APV 1993 V6-231ci 3.8L F/I Vin L
CHEVROLET LUMINA APV 1992 V6-231ci 3.8L F/I Vin L
CHEVROLET LUMINA COUPE 1994 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA COUPE 1993 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA COUPE 1991 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA EURO COUPE 1992 V6-207ci 3.4L F/I Vin X
CHEVROLET LUMINA LTZ 1998 V6-231ci 3.8L F/I Vin K
CHEVROLET MALIBU 2003 V6-189ci 3.1L F/I Vin J
CHEVROLET MALIBU 2002 V6-189ci 3.1L F/I Vin J
CHEVROLET MALIBU 2001 V6-189ci 3.1L F/I Vin J
CHEVROLET MALIBU 2000 V6-189ci 3.1L F/I Vin J
CHEVROLET MALIBU 1999 V6-189ci 3.1L F/I Vin J
CHEVROLET MALIBU 1999 V6-189ci 3.1L F/I Vin M
CHEVROLET MALIBU 1998 V6-189ci 3.1L F/I Vin M
CHEVROLET MALIBU 1997 V6-189ci 3.1L F/I Vin M
CHEVROLET MONTE CARLO 2005 V6-207ci 3.4L F/I Vin E
CHEVROLET MONTE CARLO 2005 V6-231ci 3.8L F/I Vin K
CHEVROLET MONTE CARLO 2004 V6-207ci 3.4L F/I Vin E
CHEVROLET MONTE CARLO 2004 V6-231ci 3.8L F/I Vin K (SS)
CHEVROLET MONTE CARLO 2003 V6-207ci 3.4L F/I Vin E
CHEVROLET MONTE CARLO 2003 V6-231ci 3.8L F/I Vin K (SS)
CHEVROLET MONTE CARLO 2002 V6-207ci 3.4L F/I Vin E
CHEVROLET MONTE CARLO 2002 V6-231ci 3.8L F/I Vin K (SS)
CHEVROLET MONTE CARLO 2001 V6-207ci 3.4L F/I Vin E
CHEVROLET MONTE CARLO 2000 V6-207ci 3.4L F/I Vin E
CHEVROLET MONTE CARLO 1999 V6-189ci 3.1L F/I Vin M
CHEVROLET MONTE CARLO 1999 V6-231ci 3.8L F/I Vin K
CHEVROLET MONTE CARLO 1998 V6-189ci 3.1L F/I Vin M
CHEVROLET MONTE CARLO 1997 V6-189ci 3.1L F/I Vin M
CHEVROLET MONTE CARLO 1996 V6-189ci 3.1L F/I Vin M
CHEVROLET MONTE CARLO 1995 V6-189ci 3.1L F/I Vin M
CHEVROLET MONTE CARLO SS 2005 V6-231ci 3.8L F/I Supercharged Vin 1 (SS)
CHEVROLET MONTE CARLO SS 2004 V6-231ci 3.8L F/I Supercharged Vin 1 (SS)
CHEVROLET MONTE CARLO SS 2001 V6-231ci 3.8L F/I Vin K (SS)
CHEVROLET MONTE CARLO SS 2000 V6-231ci 3.8L F/I Vin K (SS)
CHEVROLET MONTE CARLO Z34 1998 V6-231ci 3.8L F/I Vin K (Z34)
CHEVROLET MONTE CARLO Z34 1997 V6-207ci 3.4L F/I Vin X (Z34)
CHEVROLET MONTE CARLO Z34 1996 V6-207ci 3.4L F/I Vin X (Z34)
CHEVROLET MONTE CARLO Z34 1995 V6-207ci 3.4L F/I Vin X (Z34)
CHEVROLET PICKUP S10/T10 2003 L4-134ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 2002 L4-134ci 2.2L FLEX/FI Vin 5
CHEVROLET PICKUP S10/T10 2001 L4-134ci 2.2L FLEX/FI Vin 5
CHEVROLET PICKUP S10/T10 2000 L4-134ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 2000 L4-134ci 2.2L FLEX/FI Vin 5
CHEVROLET PICKUP S10/T10 1999 L4-134ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 1998 L4-133ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 1997 L4-133ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 1996 L4-133ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 1995 L4-133ci 2.2L F/I Vin 4
CHEVROLET PICKUP S10/T10 1994 L4-133ci 2.2L F/I Vin 4
CHEVROLET VENTURE 2005 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 2004 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 2003 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 2002 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 2001 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 2000 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 1999 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 1998 V6-207ci 3.4L F/I Vin E
CHEVROLET VENTURE 1997 V6-207ci 3.4L F/I Vin E
GMC PICKUP SONOMA [S15/T15] 2003 L4-134ci 2.2L F/I Vin H
GMC PICKUP SONOMA [S15/T15] 2002 L4-134ci 2.2L FLEX/FI Vin 5
GMC PICKUP SONOMA [S15/T15] 2001 L4-134ci 2.2L FLEX/FI Vin 5
GMC PICKUP SONOMA [S15/T15] 2000 L4-134ci 2.2L F/I Vin 4
GMC PICKUP SONOMA [S15/T15] 2000 L4-134ci 2.2L FLEX/FI Vin 5
GMC PICKUP SONOMA [S15/T15] 1999 L4-134ci 2.2L F/I Vin 4
GMC PICKUP SONOMA [S15/T15] 1997 L4-134ci 2.2L F/I Vin 4
GMC PICKUP SONOMA [S15/T15] 1996 L4-134ci 2.2L F/I Vin 4
GMC PICKUP SONOMA [S15/T15] 1995 L4-134ci 2.2L F/I Vin 4
GMC PICKUP SONOMA [S15/T15] 1994 L4-134ci 2.2L F/I Vin 4
GMC PICKUP SONOMA 4x2 [S15] 1998 L4-134ci 2.2L F/I Vin 4
HONDA PASSPORT 1995 V6-3165cc 3.2L F/I Vin 6VD1
HONDA PASSPORT 1994 V6-3165cc 3.2L F/I Vin 6VD1
ISUZU HOMBRE 2000 L4-2200cc 2.2L F/I Vin 4
ISUZU HOMBRE 1999 L4-2200cc 2.2L F/I Vin 4
ISUZU HOMBRE 1998 L4-2180cc 2.2L F/I Vin 4
ISUZU HOMBRE 1997 L4-2180cc 2.2L F/I Vin 4
ISUZU HOMBRE 1996 L4-2180cc 2.2L F/I Vin 4
ISUZU IMPULSE RS 1992 L4-1588cc 1.6L F/I Turbo Vin 4
ISUZU IMPULSE RS 1991 L4-1588cc 1.6L F/I Turbo Vin 4
ISUZU RODEO 1995 V6-3165cc 3.2L F/I Vin V
ISUZU RODEO 1994 V6-3165cc 3.2L F/I Vin V
ISUZU RODEO 1993 V6-3165cc 3.2L F/I Vin V
ISUZU TROOPER 1995 V6-3165cc 3.2L F/I Vin V
ISUZU TROOPER 1994 V6-3165cc 3.2L F/I Vin V
ISUZU TROOPER 1993 V6-3165cc 3.2L F/I Vin V
ISUZU TROOPER 1992 V6-3165cc 3.2L F/I Vin V
ISUZU TROOPER 1992 V6-3165cc 3.2L F/I Vin W
ISUZU TROOPER LX 1995 V6-3165cc 3.2L F/I Vin W
ISUZU TROOPER LX 1994 V6-3165cc 3.2L F/I Vin W
OLDSMOBILE ACHIEVA 1998 V6-189ci 3.1L F/I Vin M
OLDSMOBILE ACHIEVA 1997 V6-189ci 3.1L F/I Vin M
OLDSMOBILE ACHIEVA 1996 V6-189ci 3.1L F/I Vin M
OLDSMOBILE ACHIEVA 1995 V6-189ci 3.1L F/I Vin M
OLDSMOBILE ACHIEVA 1994 V6-189ci 3.1L F/I Vin M
OLDSMOBILE ACHIEVA 1993 V6-204ci 3.3L F/I Vin N
OLDSMOBILE ACHIEVA 1992 V6-204ci 3.3L F/I Vin N
OLDSMOBILE ALERO 2004 V6-207ci 3.4L F/I Vin E
OLDSMOBILE ALERO 2003 V6-207ci 3.4L F/I Vin E
OLDSMOBILE ALERO 2002 V6-207ci 3.4L F/I Vin E
OLDSMOBILE ALERO 2001 V6-207ci 3.4L F/I Vin E
OLDSMOBILE ALERO 2000 V6-207ci 3.4L F/I Vin E
OLDSMOBILE ALERO 1999 V6-207ci 3.4L F/I Vin E
OLDSMOBILE AURORA 1999 V8-244ci 4.0L F/I Vin C
OLDSMOBILE AURORA 1998 V8-244ci 4.0L F/I Vin C
OLDSMOBILE AURORA 1997 V8-244ci 4.0L F/I Vin C
OLDSMOBILE AURORA 1996 V8-244ci 4.0L F/I Vin C
OLDSMOBILE AURORA 1995 V8-244ci 4.0L F/I Vin C
OLDSMOBILE CALAIS 1987 L4-151ci 2.5L F/I Vin U
OLDSMOBILE CUTLASS 1999 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS 1998 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS CALAIS 1991 L4-151ci 2.5L F/I Vin U
OLDSMOBILE CUTLASS CALAIS 1991 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CALAIS 1990 L4-151ci 2.5L F/I Vin U
OLDSMOBILE CUTLASS CALAIS 1990 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CALAIS 1989 L4-151ci 2.5L F/I Vin U
OLDSMOBILE CUTLASS CALAIS 1989 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CALAIS 1988 L4-151ci 2.5L F/I Vin U
OLDSMOBILE CUTLASS CIERA 1996 L4-134ci 2.2L F/I Vin 4
OLDSMOBILE CUTLASS CIERA 1996 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS CIERA 1995 L4-134ci 2.2L F/I Vin 4
OLDSMOBILE CUTLASS CIERA 1995 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS CIERA 1994 L4-134ci 2.2L F/I Vin 4
OLDSMOBILE CUTLASS CIERA 1994 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS CIERA 1993 L4-134ci 2.2L F/I Vin 4
OLDSMOBILE CUTLASS CIERA 1993 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CIERA 1992 L4-151ci 2.5L F/I Vin R
OLDSMOBILE CUTLASS CIERA 1992 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CIERA 1991 L4-151ci 2.5L F/I Vin R
OLDSMOBILE CUTLASS CIERA 1991 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CIERA 1990 L4-151ci 2.5L F/I Vin R
OLDSMOBILE CUTLASS CIERA 1990 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CIERA 1989 L4-151ci 2.5L F/I Vin R
OLDSMOBILE CUTLASS CIERA 1989 V6-173ci 2.8L F/I Vin W
OLDSMOBILE CUTLASS CIERA 1989 V6-204ci 3.3L F/I Vin N
OLDSMOBILE CUTLASS CIERA 1988 L4-151ci 2.5L F/I Vin R
OLDSMOBILE CUTLASS CIERA 1988 V6-173ci 2.8L F/I Vin W
OLDSMOBILE CUTLASS CIERA 1988 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE CUTLASS CIERA 1987 L4-151ci 2.5L F/I Vin R
OLDSMOBILE CUTLASS CIERA 1987 V6-173ci 2.8L F/I Vin W
OLDSMOBILE CUTLASS CIERA 1987 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE CUTLASS CIERA 1986 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE CUTLASS SUPREME 1997 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS SUPREME 1996 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS SUPREME 1996 V6-207ci 3.4L F/I Vin X
OLDSMOBILE CUTLASS SUPREME 1995 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS SUPREME 1995 V6-207ci 3.4L F/I Vin X
OLDSMOBILE CUTLASS SUPREME 1994 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS SUPREME 1994 V6-207ci 3.4L F/I Vin X
OLDSMOBILE CUTLASS SUPREME 1993 V6-189ci 3.1L F/I Vin M
OLDSMOBILE CUTLASS SUPREME 1993 V6-189ci 3.1L F/I Vin T
OLDSMOBILE CUTLASS SUPREME 1993 V6-207ci 3.4L F/I Vin X
OLDSMOBILE CUTLASS SUPREME 1992 V6-189ci 3.1L F/I Vin T
OLDSMOBILE CUTLASS SUPREME 1992 V6-207ci 3.4L F/I Vin X
OLDSMOBILE CUTLASS SUPREME 1991 V6-189ci 3.1L F/I Vin T
OLDSMOBILE CUTLASS SUPREME 1991 V6-207ci 3.4L F/I Vin X
OLDSMOBILE CUTLASS SUPREME 1990 V6-189ci 3.1L F/I Vin T
OLDSMOBILE CUTLASS SUPREME 1989 V6-173ci 2.8L F/I Vin W
OLDSMOBILE CUTLASS SUPREME 1989 V6-189ci 3.1L F/I Vin T
OLDSMOBILE CUTLASS SUPREME 1988 V6-173ci 2.8L F/I Vin W
OLDSMOBILE DELTA 88 1999 V6-231ci 3.8L F/I Vin K
OLDSMOBILE DELTA 88 1988 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE DELTA 88 1987 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE DELTA 88 1986 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE EIGHTY-EIGHT 1998 V6-231ci 3.8L F/I Vin K
OLDSMOBILE EIGHTY-EIGHT 1997 V6-231ci 3.8L F/I Vin K
OLDSMOBILE EIGHTY-EIGHT 1996 V6-231ci 3.8L F/I Vin K
OLDSMOBILE EIGHTY-EIGHT LSS 1996 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE EIGHTY-EIGHT LSS 1996 V6-231ci 3.8L F/I Vin K
OLDSMOBILE EIGHTY-EIGHT LSS 1995 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE EIGHTY-EIGHT ROYALE 1995 V6-231ci 3.8L F/I Vin K
OLDSMOBILE EIGHTY-EIGHT ROYALE 1994 V6-231ci 3.8L F/I Vin L
OLDSMOBILE EIGHTY-EIGHT ROYALE 1993 V6-231ci 3.8L F/I Vin L
OLDSMOBILE EIGHTY-EIGHT ROYALE 1992 V6-231ci 3.8L F/I Vin L
OLDSMOBILE FIRENZA 1988 L4-121ci 2.0L F/I Vin 1
OLDSMOBILE FIRENZA 1987 L4-121ci 2.0L F/I Vin 1
OLDSMOBILE FIRENZA 1987 V6-173ci 2.8L F/I Vin W
OLDSMOBILE INTRIGUE 1999 V6-231ci 3.8L F/I Vin K
OLDSMOBILE INTRIGUE 1998 V6-231ci 3.8L F/I Vin K
OLDSMOBILE LSS 1999 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE LSS 1999 V6-231ci 3.8L F/I Vin K
OLDSMOBILE LSS 1998 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE LSS 1998 V6-231ci 3.8L F/I Vin K
OLDSMOBILE LSS 1997 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE LSS 1997 V6-231ci 3.8L F/I Vin K
OLDSMOBILE NINETY-EIGHT 1987 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE NINETY-EIGHT 1986 V6-231ci 3.8L F/I Vin B
OLDSMOBILE NINETY-EIGHT REGENCY 1996 V6-231ci 3.8L F/I Vin K
OLDSMOBILE NINETY-EIGHT REGENCY 1995 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE NINETY-EIGHT REGENCY 1995 V6-231ci 3.8L F/I Vin K
OLDSMOBILE NINETY-EIGHT REGENCY 1994 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE NINETY-EIGHT REGENCY 1994 V6-231ci 3.8L F/I Vin L
OLDSMOBILE NINETY-EIGHT REGENCY 1993 V6-231ci 3.8L F/I Vin L
OLDSMOBILE NINETY-EIGHT REGENCY 1992 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE NINETY-EIGHT REGENCY 1992 V6-231ci 3.8L F/I Vin L
OLDSMOBILE NINETY-EIGHT REGENCY TS 1993 V6-231ci 3.8L F/I Supercharged Vin 1
OLDSMOBILE REGENCY 1998 V6-231ci 3.8L F/I Vin K
OLDSMOBILE REGENCY 1997 V6-231ci 3.8L F/I Vin K
OLDSMOBILE SILHOUETTE [OLDS] 2004 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 2003 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 2002 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 2001 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 2000 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 1999 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 1998 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 1997 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 1996 V6-207ci 3.4L F/I Vin E
OLDSMOBILE SILHOUETTE [OLDS] 1995 V6-231ci 3.8L F/I Vin L
OLDSMOBILE SILHOUETTE [OLDS] 1994 V6-231ci 3.8L F/I Vin L
OLDSMOBILE SILHOUETTE [OLDS] 1993 V6-231ci 3.8L F/I Vin L
OLDSMOBILE SILHOUETTE [OLDS] 1992 V6-231ci 3.8L F/I Vin L
OLDSMOBILE TORONADO 1992 V6-231ci 3.8L F/I Vin L
OLDSMOBILE TORONADO 1991 V6-231ci 3.8L F/I Vin L
OLDSMOBILE TORONADO 1987 V6-231ci 3.8L F/I Vin 3
OLDSMOBILE TORONADO 1986 V6-231ci 3.8L F/I Vin B
PONTIAC 6000 1991 L4-151ci 2.5L F/I Vin R
PONTIAC 6000 1991 V6-189ci 3.1L F/I Vin T
PONTIAC 6000 1990 L4-151ci 2.5L F/I Vin R
PONTIAC 6000 1990 V6-189ci 3.1L F/I Vin T
PONTIAC 6000 1989 L4-151ci 2.5L F/I Vin R
PONTIAC 6000 1989 V6-173ci 2.8L F/I Vin W
PONTIAC 6000 1988 L4-151ci 2.5L F/I Vin R
PONTIAC 6000 1988 V6-173ci 2.8L F/I Vin W
PONTIAC 6000 1988 V6-189ci 3.1L F/I Vin T
PONTIAC 6000 1987 L4-151ci 2.5L F/I Vin R
PONTIAC 6000 1987 V6-173ci 2.8L F/I Vin W
PONTIAC 6000 STE 1989 V6-189ci 3.1L F/I Vin T
PONTIAC AZTEK 2005 V6-207ci 3.4L F/I Vin E
PONTIAC AZTEK 2004 V6-207ci 3.4L F/I Vin E
PONTIAC AZTEK 2003 V6-207ci 3.4L F/I Vin E
PONTIAC AZTEK 2002 V6-207ci 3.4L F/I Vin E
PONTIAC AZTEK 2001 V6-207ci 3.4L F/I Vin E
PONTIAC BONNEVILLE 2005 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 2004 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 2003 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE 2003 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 2002 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE 2002 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 2001 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 2000 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 1999 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE 1999 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 1998 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 1997 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE 1997 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE 1988 V6-231ci 3.8L F/I Vin 3
PONTIAC BONNEVILLE 1987 V6-231ci 3.8L F/I Vin 3
PONTIAC BONNEVILLE SE 1996 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE SE 1995 V6-231ci 3.8L F/I Vin K
PONTIAC BONNEVILLE SE 1994 V6-231ci 3.8L F/I Vin L
PONTIAC BONNEVILLE SE 1993 V6-231ci 3.8L F/I Vin L
PONTIAC BONNEVILLE SE 1992 V6-231ci 3.8L F/I Vin L
PONTIAC BONNEVILLE SSE 1996 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSE 1995 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSE 1993 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSEi 2001 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSEi 2000 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSEi 1998 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSEi 1994 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC BONNEVILLE SSEi 1992 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC FIERO 1988 L4-151ci 2.5L F/I Vin R
PONTIAC FIERO 1987 L4-151ci 2.5L F/I Vin R
PONTIAC FIREBIRD 2002 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 2001 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 2000 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 1999 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 1998 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 1997 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 1996 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 1995 V6-207ci 3.4L F/I Vin S
PONTIAC FIREBIRD 1995 V6-231ci 3.8L F/I Vin K
PONTIAC FIREBIRD 1994 V6-207ci 3.4L F/I Vin S
PONTIAC FIREBIRD 1993 V6-207ci 3.4L F/I Vin S
PONTIAC GRAND AM 2005 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 2004 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 2003 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 2002 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 2001 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 2000 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 1999 V6-207ci 3.4L F/I Vin E
PONTIAC GRAND AM 1998 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND AM 1997 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND AM 1996 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND AM 1995 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND AM 1994 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND AM 1993 V6-204ci 3.3L F/I Vin N
PONTIAC GRAND AM 1992 V6-204ci 3.3L F/I Vin N
PONTIAC GRAND AM 1991 L4-151ci 2.5L F/I Vin U
PONTIAC GRAND AM 1990 L4-151ci 2.5L F/I Vin U
PONTIAC GRAND AM 1989 L4-151ci 2.5L F/I Vin U
PONTIAC GRAND AM 1988 L4-151ci 2.5L F/I Vin U
PONTIAC GRAND AM 1987 L4-151ci 2.5L F/I Vin U
PONTIAC GRAND PRIX 2007 V6-231ci 3.8L F/I Supercharged Vin 4
PONTIAC GRAND PRIX 2007 V6-231ci 3.8L F/I Vin 2
PONTIAC GRAND PRIX 2006 V6-231ci 3.8L F/I Supercharged Vin 4
PONTIAC GRAND PRIX 2006 V6-231ci 3.8L F/I Vin 2
PONTIAC GRAND PRIX 2005 V6-231ci 3.8L F/I Supercharged Vin 4
PONTIAC GRAND PRIX 2005 V6-231ci 3.8L F/I Vin 2
PONTIAC GRAND PRIX 2004 V6-231ci 3.8L F/I Supercharged Vin 4
PONTIAC GRAND PRIX 2004 V6-231ci 3.8L F/I Vin 2
PONTIAC GRAND PRIX 2003 V6-189ci 3.1L F/I Vin J
PONTIAC GRAND PRIX 2003 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC GRAND PRIX 2003 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 2002 V6-189ci 3.1L F/I Vin J
PONTIAC GRAND PRIX 2002 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC GRAND PRIX 2002 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 2001 V6-189ci 3.1L F/I Vin J
PONTIAC GRAND PRIX 2001 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 2000 V6-189ci 3.1L F/I Vin J
PONTIAC GRAND PRIX 2000 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 1999 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND PRIX 1999 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC GRAND PRIX 1999 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 1998 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND PRIX 1998 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 1997 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND PRIX 1997 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC GRAND PRIX 1997 V6-231ci 3.8L F/I Vin K
PONTIAC GRAND PRIX 1996 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND PRIX 1996 V6-207ci 3.4L F/I Vin X
PONTIAC GRAND PRIX 1995 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND PRIX 1995 V6-207ci 3.4L F/I Vin X
PONTIAC GRAND PRIX 1994 V6-189ci 3.1L F/I Vin M
PONTIAC GRAND PRIX 1994 V6-207ci 3.4L F/I Vin X
PONTIAC GRAND PRIX 1993 V6-189ci 3.1L F/I Vin T
PONTIAC GRAND PRIX 1993 V6-207ci 3.4L F/I Vin X
PONTIAC GRAND PRIX 1992 V6-189ci 3.1L F/I Vin T
PONTIAC GRAND PRIX 1992 V6-207ci 3.4L F/I Vin X
PONTIAC GRAND PRIX 1991 V6-189ci 3.1L F/I Vin T
PONTIAC GRAND PRIX 1991 V6-207ci 3.4L F/I Vin X
PONTIAC GRAND PRIX 1990 V6-189ci 3.1L F/I Turbo Vin V
PONTIAC GRAND PRIX 1990 V6-189ci 3.1L F/I Vin T
PONTIAC GRAND PRIX 1989 V6-173ci 2.8L F/I Vin W
PONTIAC GRAND PRIX 1989 V6-189ci 3.1L F/I Turbo Vin V
PONTIAC GRAND PRIX 1989 V6-189ci 3.1L F/I Vin T
PONTIAC GRAND PRIX 1988 V6-173ci 2.8L F/I Vin W
PONTIAC GRAND PRIX GTP 2001 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC GRAND PRIX GTP 2000 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC GRAND PRIX GTP 1998 V6-231ci 3.8L F/I Supercharged Vin 1
PONTIAC MONTANA 2005 V6-207ci 3.4L F/I Vin E
PONTIAC MONTANA 2004 V6-207ci 3.4L F/I Vin E
PONTIAC MONTANA 2003 V6-207ci 3.4L F/I Vin E
PONTIAC MONTANA 2002 V6-207ci 3.4L F/I Vin E
PONTIAC MONTANA 2001 V6-207ci 3.4L F/I Vin E
PONTIAC MONTANA 2000 V6-207ci 3.4L F/I Vin E
PONTIAC MONTANA 1999 V6-207ci 3.4L F/I Vin E
PONTIAC SUNBIRD 1994 V6-189ci 3.1L F/I Vin T
PONTIAC SUNBIRD 1993 V6-189ci 3.1L F/I Vin T
PONTIAC SUNBIRD 1992 V6-189ci 3.1L F/I Vin T
PONTIAC SUNBIRD 1991 V6-189ci 3.1L F/I Vin T
PONTIAC SUNFIRE 2002 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 2001 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 2000 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 1999 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 1998 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 1997 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 1996 L4-134ci 2.2L F/I Vin 4
PONTIAC SUNFIRE 1995 L4-134ci 2.2L F/I Vin 4
PONTIAC TEMPEST [CAN] 1991 L4-134ci 2.2L F/I Vin G
PONTIAC TEMPEST [CAN] 1990 L4-134ci 2.2L F/I Vin G
PONTIAC TRANS SPORT 1998 V6-207ci 3.4L F/I Vin E
PONTIAC TRANS SPORT 1997 V6-207ci 3.4L F/I Vin E
PONTIAC TRANS SPORT 1996 V6-207ci 3.4L F/I Vin E
PONTIAC TRANS SPORT 1995 V6-231ci 3.8L F/I Vin L
PONTIAC TRANS SPORT 1994 V6-231ci 3.8L F/I Vin L
PONTIAC TRANS SPORT 1993 V6-231ci 3.8L F/I Vin L
PONTIAC TRANS SPORT 1992 V6-231ci 3.8L F/I Vin L
nitroman
Postby Doug » Thu 30.07.2009, 22:29
knowing Matt, he probably hand typed the above list to be sure it was done right :wink:
Postby jackdaniel » Mon 26.10.2009, 05:58
Hey, has anyone thought of a coil-on-plug modification????
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
jackdaniel
Postby Peter_W » Sun 04.05.2014, 19:56
tweetdriver63 wrote:I just replaced my plugs, leads, and coil packs. MSD coil packs, NGK plugs, and performance leads with firebraid from Robie the Robot.
A VERY helpful post ~6 years later! :smt023. Having cruised along all these years on the original coil packs, I was suddenly running on 2 cylinders. Referring to the excellent wiki write-up, I moved the header tank and intake hose to find my coil pack assembly further obscured by two rigid A/C plumbing pipes. Finding this post (upon which the second section of the wiki entry is based) l took the tip of buying the new coil packs and by referring to them for the bolt locations the R&R was just as easy as described.
Peter_W
Postby Brit-Car-Nut » Sun 04.05.2014, 20:32
I figured it out without the Wiki but looking at it now I realize there is no coil cross-reference except the MSD coils.
The Air Conditioning Lines are a real pain since the block your ability to see the bolts, but once you figure it out, the bolts are easy to remove and reinstall.
JUST REMEMBER to replace the small oval rubber gaskets so the connections stay dry. Obviously, you need to remove the old ones.
The coil pack used is a STANDARD ISSUE GM Coil from the early 1990s and are readily available for around $10.00 each in the US.
The most common part number to look for is DR39 as it will be the most common replacement.
Other numbers include 10468391, 10472401, 1103745, 1103746, 10482928, 10467067, 10468391, 10472401, D555, D539, D540 and E530C.
Why so many different numbers? Over the years GM has had multiple companies make the coils for them and they had to assign new numbers each time that happened. Then there are the Aftermarket suppliers like Standard Motor Products, Echlin, and BWD to name a few.
The bottom line is that a lot of M100s are still running on their original coil packs and if the standard packs have been that good, the name brand replacements should last just as long without having to buy high performance coils that are not needed unless you get above 8,000 RPMs or you are using a very cold spark plug.
So, if anyone is looking for a replacement coil, they only need to look at the early 1990 GM 4 cylinder cars to find a good and affordable solution. Rock Auto lists the DR39 and has a reasonable selection of suppliers.
