N/A Coil ??
N/A Coil ??
Postby GROMIT » Sun 05.07.2009, 10:12
Hi all my na has started to show probs in the last 4 days on slowing down it making a large bang (and it is loud ) a bit of lost power then ok untill yesterday
traving at 60 mph slowed down engine loses all power will not start no ecu codes had to be towed back home at home turn key starts 1st time the car runs fine good tickover rev ok has from start , has 8 mouth old ht leads cap roter arm plugs and new timing belt fitted same time by steve w and with no cas help ? if its the coil is there a of the shelf part you can buy and can you check the old one any input would be great thanks gromit.
GROMIT
Re: N/A Coil ??
Postby Specky » Sun 05.07.2009, 11:05
There's two N/A coils available from Lotus,
I have a battered old style (Quite expensive, but still available) and a newer one to replace it...
I got the new one for a few quid from the Lotus aftersales, they are still available.
Send an email to ACoughlan@lotuscars.co.uk and ask for A100E6040H, N/A coil, £12.77
It's free delivery to your local Lotus dealership. (You specify which one in your email)
http://www.lotus60thanniversary.com/forsale.php
Nearly forgot Aidan is off till monday, so send your email then, or you'll get an out of office reply.
