by luluchiboy » Sun 04.10.2009, 17:57
I just read the wiki on this but couldn't figure it out.
Do you turn clockwise to increase idle speed/ rpms? or counterclockwise?
My car is having multiple issues with idling. I just wanted to turn it to the max idle speed/ highest rpms to see if it will even stay afloat vs stalling out.
Thanks in advance.
luluchiboy
- Tinkerer
by RayD » Sun 04.10.2009, 18:32
I'll add it to the Wiki ... in the mean time the revs increase by turning the screw anticlockwise ... outwards ... opening a valve as it were.
A couple of people have found the screw is 1½ turns out from fully in when doing 950RPM in service mode.
- Forum Member
