John_W wrote:a Hall effect sensor on the way out.
It sounds to me more like this than a boost issue.
HJ2 wrote:At least somebody is paying attention![]()
Next time I'll try to read first, then to answer
Brit-Car-Nut wrote:The car in South Carolina did have a bad Hall Effect Sensor which kept putting up error code 41. They replaced it and then the coils which solved the basic crappy running and the error codes but it still slammed into shut down when they hit 4200 rpm. There was never a code set for overboost.
Is it possible he has an modified "MBC" system and the MAP sensor is not recognizing the overboost?
I am not sure why he is getting a new wastegate actuator made since the one used on the M100 is common to the Isuzu, probe, t-bird and the Mazda 626. I was able to pick up a good used one from the local turbo shop.
