by KenS » Thu 03.01.2019, 20:57
HI, can anyone help with the dimensions of the o-ring on the fuel regulator (plugging into the fuel rail)? I have new injectors ready to fit, then thought the regulator o-ring will probably need changing, so having one ready may make this a fairly quick job. - I guess Viton is the type to get? I think I can get them locally if I have the size. Thanks.
S2 M100 NMY #285
N/A 2010 Evora
KenS
by KenS » Fri 11.01.2019, 18:07
I can confirm that the fuel regulator O ring, into the fuel rail is 13mm ID x 2.5mm CS. Replaced the injectors and this O ring, all runs fine.
S2 M100 NMY #285
N/A 2010 Evora
KenS
Users browsing this forum: NickVR6 and 4 guests
