by kbee » Sun 02.05.2021, 19:54
Hi just got my first Elan , it is ticking over at about 1250rpm , is this normal and if not can it be adjusted thanks
kbee
by Rambo » Sun 02.05.2021, 21:28
No ! Far too fast. You should be looking at setting ~950 rpm in service mode
- Don't push me
by Simon_P » Sun 02.05.2021, 21:55
1250 rpm just after starting going to 950 warm.
check for detached vac pipes.
by kbee » Mon 03.05.2021, 13:22
excuse my ignorance butvwhat is service mode thanks
kbee
by Fredjohn » Mon 03.05.2021, 16:35
It's used to make adjustments. You connect the 2 wires in the ALDL plug to obtain service mode. As the Lotus special tool is unobtainable, a paperclip will do.
Suggest you download the workshop manuals and have a browse, and also have a read of the wikiLEC. Plenty written up on there.
Good luck with your project though. If you can't find answers in the Manuals or wikiLEC, still don't be afraid to ask. Don't ask don't get!
by Rambo » Mon 03.05.2021, 16:38
kbee wrote:excuse my ignorance butvwhat is service mode thanks
Service mode is when you short out pins A and B on the ALDL plug located behind the glove box. Same as if you were doing a "paperclip" diagnostics check. So, get a paperclip, make a U shape and insert in pin A and B (black and white wires from memory)
http://wikilec.com/view/TickoverAlso gave a look here
http://wikilec.com/view/Check_Engine_Light_(CEL) there is a schematic showing the ALDL plug and the correct pins to short out.
You may as well try looking to see if there are any error codes stored after or before you change your idle adjustment
posting at the same time as John
- Don't push me
