Conversion to Coil on Plug coil packs
Postby chrisP » Tue 29.06.2021, 13:59
A question, has anyone done any research on getting a stronger spark by - fitting the more modern coil packs, that mount on the plug rather than having HT leads? I'm thinking it should improve the burn...?
chrisP
Re: Conversion to Coil on Plug coil packs
Postby BarryDalHerbert » Mon 16.08.2021, 04:34
Not an answer, just some further information that might be of interest:
https://www.aa1car.com/library/copign.htm
Tuross Head NSW
BdH
16-Aug-21 13:34
BarryDalHerbert
Postby BarryDalHerbert » Fri 29.12.2023, 11:53
This Youtube video -TFS: Coil Per Cylinder Ignition Upgrade- : https://www.youtube.com/watch?v=P5dasfSt85Y
updates a wasted spark Mitsubishi 16 value, 4 cylinder engine to coil-on-plug ignition.
Aside from a comment in the video that performance at high revs were improved, there was no mention of what improvements (if any) were achieved, but there is a response to this question in one of the comments where this answer was given:
"It does add a little bit on it's own, but it's not a massive difference. It's more aimed at supporting future mods and tuning to actually create more power."
So a small performance improvement for significant farnarckling around, and lots of money. Not really very appealing...
BdH
Tuross Head
Fri 29-Dec-23 21:53
You will get to hear the very amusing USA pronunciation of the word SOLDERING!
BarryDalHerbert
