Fuel pump not running!
Postby Jayeme69 » Fri 19.08.2022, 17:55
On my recently acquired basket case , i can only get it to run by supplying power directly to the fuel pump, i have power and an earth at the relay but don't know what i should be looking for at pin No 1 ? anyone?
Jayeme69
Re: Fuel pump not running!
Postby Simon_P » Sun 21.08.2022, 11:11
Do you have an alarm or immobiliser?
The ECU is behind the glovebox
The pin configuration is in manuals EMK/EMJ on about page 98 with a description of what you should see at each pin. Remove the blue clip to get better access to the back of the pins.
Postby Jayeme69 » Sun 21.08.2022, 11:44
Simon_P wrote:Do you have an alarm or immobiliser?
Yes it has an immobiliser but that seems to be working as it disables cranking when armed, unless it disables cranking and the fuel pump but is only re enabling the crank and not the pump? :banghead:
Jayeme69
Postby robertverhey » Mon 22.08.2022, 00:46
Has the inertia switch tripped perhaps?
robertverhey
Postby Tuga2112 » Mon 22.08.2022, 08:09
did you ask the same question in a different place ?
