Fuel Pump Relay Bosch 332017-100
Postby Tedebayer88 » Thu 13.10.2022, 15:48
Working on a US model 91 Lotus Elan M100 with fuel relay and inertia switch behind the driver's seat behind speaker wall.
I am troubleshooting the fuel pump and regulator... and had ZERO luck trying to acquire a Fuel Pump Relay. I may not need it but if I do, take a bit to get it this side of the pond so would like to order a spare.
Is there any other relay that cross references with this one that people use? I read that HELLA 4RA933766-111 was a direct replacement and pins seem to match but not confirmed it works.
Thanks for any help! Much Appreciated.
Tedebayer88
Re: Fuel Pump Relay Bosch 332017-100
Postby FunElan » Thu 13.10.2022, 18:33
FunElan
