by pte123 » Sun 01.11.2026, 19:03
Hi All,
Just looking for some help troubleshooting. The exhaust is very sooty and it smells really rich. Does anyone have any thoughts on where I should start with troubleshooting?
I do have access to Elanscan. The idle seems okay and there's no check engine light on the dash.
Much appreciated! Phil
pte123
by dapinky » Sun 01.11.2026, 19:17
My first thought is to see what Elanscan is saying the coolant temperature is.......
...... this sounds like a typical 'overfueling' situation, which is often brought about by the ECU thinking that the car is running much colder than it actually is, so throws extra petrol into the system.
If it is giving a low reading, the CTS probably needs changing, which is a fairly quick and easy thing to do, with aftermarket parts which can be purchased cheaply (under £20).
- LEC Administrator
