Hard starting problems - Faulty FPR
Postby Rudz » Tue 12.07.2005, 09:43
Hi Guys,
Anybody has advice on where to get the Fuel Pressure Regulator (FPR) on our Elan (Turbo) ? Apparently, LOTUS sells it as a complete assembly together with the fuel rail & injectors but I m very sure it can be bought seperately. I have already dismantled it. Any cross-reference part numbers for this ? Which other car might be using the same FPR ?
Thanks for any advice ... Rudz
Rudz
Postby Ashaman » Wed 13.07.2005, 02:50
The Isuzus of course....
You could install an aftermarket adjustable one though, that is the way I would go if it turns out to be an expensive item!
Ashaman
Postby Doc Fizzix » Wed 13.07.2005, 05:14
I think I have an extra one sitting in the garage if you need it :idea:
Doc Fizzix
Postby Jeff » Fri 15.07.2005, 01:16
Yup, you can't get the fpr separately. I believe I used one from a Toyota, but I had to reroute the vacuum line and remove the engine bracket. I will continue to try to match up one like the OE part.
Jeff
