intermitent running problems! help!!
Postby matt_elan » Tue 09.08.2005, 17:46
Hi guys, ive got a problem that I thought was just something wet because of me jetwashin but im not sure now. Basically it mis fires under load. it seems 2 go away, then come bak! one day fine, (or 1 hour) and the next, misfiring! :x ive changed the plugs, cleaned loads of connections and still it returns! :cry: dont no if it cud make a difference but my speedo cable is shot and waitin on a new 1, I know there is a speed sensor, cud this play a part? cud it b the leads? tho i wud av thought if it was leads it wud either work or not!? Coil pack? hope someones got some ideas cos its doin my head in!!!
cheers
matt
matt_elan
Postby NIL8379 » Tue 09.08.2005, 17:55
I'd put my money on a duff lead.
I had a terrible intermittent fault on an Astra, turned out 2b a lead in the end. Would run without a misfire for weeks and then come and go. I should have changed the leads b4 I changed the electronic ignition module at £75.00.
Cured the fault with a 25p lead from an oddments bin at a local spares shop..............DOH!!!!!
When I dissected the faulty lead it was corrosion between the metal cap and the inner carbon fibres..........very irritating.
My philosophy is to change the cheap stuff first now.
NIL8379
Postby Doug » Wed 10.08.2005, 03:45
agree with good advice above
leads suspect
less likely coil is suspect
CAS - Hall Sensor is suspect
check the leads and replace the speedo cable, see if any check engine lights are showing up after that . . .
Postby JLSELAN » Wed 10.08.2005, 04:12
Also agree with advice so far.
A way to evaluate the soundness of the HV leads is to check under the hood (bonnet) at night as you change engine speeds to see if there is any electrical arcing to ground (earth) from the leads. You may be amazed by the light show you see :shock: .
Cheers, Joel
JLSELAN
Postby Doc Fizzix » Wed 10.08.2005, 05:19
Just for fun, not likley but I spent sever weeks replacing plug wires, fuel regulator and fuel pump, sensors, and the coil only to find that my problem was with the injectors. Car ran like it was missing and I thought it was an ignition problem. The last place I was looking was bad injectors.
My two cents worth
Doc Fizzix
Postby matt_elan » Fri 12.08.2005, 07:13
Ive ordered some magnacor leads but will take a goog few days to arrive, so i ll have 2 wait n c!! i ll let ya no the out come.
matt_elan
Postby piston_broke » Sat 13.08.2005, 22:56
have you checked the fault codes
and
check as many of the earths as you can find-I had a problem which was an earth off by the injectors
good hunting
cheers
d
piston_broke
Postby matt_elan » Wed 17.08.2005, 08:58
are there any main earth points I shud b checking? :?
matt_elan
Intermitent running.
Postby Ade » Thu 01.09.2005, 20:07
Hi.
we seem to have the same fault. I have also tried new plugs and have assumed my plug leads are o.k because they were new with a new engine, I know foolish, they could still be faulty. I am going to try a new fuel filter and then work my way through all possibles. I have checked for fault codes, no faults shown. I will let you know if I fix it, but you know the problem, just when you think its fixed, it returns. Steve from SJ sports cars said these are the most difficult faults to find if there are no codes.
Best of luck
Ade.
Ade
Postby matt_elan » Mon 05.09.2005, 18:34
:burnout: new leads and that cured it!! cheers guys!
matt_elan
Users browsing this forum: Chas54 and 2 guests
