by Oliver » Mon 14.11.2005, 22:24
Thanks to Nige and Clemmo for all the advise regarding my dodgy running problem. A company in the USA (
www.vintageperformance.com) do a high performance igniter part no. D2003. I`m trying to order one. I`ll keep you posted.
Oliver
by Nige » Wed 16.11.2005, 17:27
Good spot, I see they do a coil as well. Keep us posted.
Back in Blighty
Nige
- LEC Administrator
by Oliver » Sun 18.12.2005, 00:19
I`ve just fitted my intermtor pattern ignitor unit and i am still experiencing an intermittent `flat spot`. I am sure i`ll conquer the problem before Donington!
Oliver
by Oliver » Tue 17.01.2006, 21:40
Just got it MOT`d today, still got running probs. Difficult to start from cold, buggers about `till warm then runs fine. Next on the list for replacement are coolant teperature sensor, then EGR valve, IAC valve, and although my ignition coil is only two years old, i might try to get a Daewoo Espero one to try. Oh, the MOT emissions test was fine, but maybe a bit weak. Only spent a year trying to solve the problem. Shows how good my diagnostic skills are (not). Ho hum..
Just been looking a another thread and i`ve been overlooking the vaccum pipes. I think i`ll give them a thorough check.
Oliver
by Nige » Tue 17.01.2006, 23:49
Have a brand new unused NA coil (Lotus) in my 'rainy day' spares box should you need to try it.
Back in Blighty
Nige
- LEC Administrator
by Oliver » Thu 19.01.2006, 19:29
Thanks Nige, I`ve ordered a new CTS from a Vauxhall dealer, i`ll try that then ley you know. Cheers mate.
Oliver
by Oliver » Thu 19.01.2006, 19:38
By the way, i trust your two are going ok? it`s easy to get wrapped up with your own probs you know!
Oliver
by Oliver » Thu 19.01.2006, 20:22
Oh yes, call me slow but i`ve just worked out the French!
Oliver
by Oliver » Fri 27.01.2006, 00:43
Fitted new CTS, problem still apparent, back to the drawing board. Ho hum. TPS off next and i shall test more vacuum hoses for leaks/blockages.
Oliver
