missy missfire
missy missfire
Postby stevo » Wed 22.03.2006, 17:31
missy decided to intermitantly get a bit stroppy at donny with a slight missfire and full on very stroppy on the last 50 miles home with some serious missing , cel, and limp home mode three times. i've paper cliped her today and im getting 33,41,42 and 54. the miss happens as you open the throttle at low -mid revs and when i go over bumps. any ideas?
stevo
Postby Enright » Wed 22.03.2006, 18:05
What the hell is this, some sort of Elan virus?
They're all falling over at the same time! :shock: :?
Postby timmo » Wed 22.03.2006, 18:22
steve - check all ecu connections are secure, same happened to mine, it was a loose lead onto the ECU.
I wonder how much deeper the ocean would be without sponges.
timmo
Postby Monty » Wed 22.03.2006, 18:37
Stevo,
Check the connectors for the ECU but I would say it`s a CAS problem/HALL, i got some of those codes on pinky 1 changed the HALL and had no more error codes. funny enough even after stuffing it in to a barrier i still got no error codes LMAO :-D
Postby stevo » Thu 23.03.2006, 16:52
well i pulled my wire and it came off in my hand.
bad connection to the cas. job done. :-D
stevo
Postby Stef » Thu 23.03.2006, 17:11
If in doubt pull it off eh?! :-D
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby timmo » Thu 23.03.2006, 18:44
Hate it when it comes off in your hand. :wink:
timmo
