by kmckmc » Tue 24.10.2006, 23:25
Please advise.
Elan M100 S2
kmckmc
by Doc Fizzix » Wed 25.10.2006, 01:30
Your answer is:
NO
I am not sure if you can see my starter in the picture bellow but I can tell from your picture that yours is not the same, it may work but it is deffinately not the same. It looks like your connections are on the wrong side
Doc Fizzix
by Doc Fizzix » Thu 26.10.2006, 18:16
Can you post a different pic of the starter? I want to see the other side, its not original but it might have the correct hook-ups but I need to see the other side
Doc Fizzix
by kmckmc » Fri 27.10.2006, 00:13
Elan M100 S2
kmckmc
by Doc Fizzix » Fri 27.10.2006, 02:32
Ok, much better. Not original but looks like it will work. Important, what are the specs
Doc Fizzix
by kmckmc » Fri 27.10.2006, 03:31
Elan M100 S2
kmckmc
by Ekapol » Wed 01.11.2006, 20:16
So clean Doc
Is that in your garage??
Ekapol
by desmondsee » Mon 13.11.2006, 06:05
I have been having intermittent starts for the last 3 months...brought to local workshop and lotus dealer and switced several items including battery, spark plugs, fuel pump. Finally, it was diagnosed as the starter. I thought i had to pay $$$ and wait indefinitely for another overseas order. Upon removing the starter, it was actually a rather common unit made by NipponDenso. Brought to a specialist shop, witnessed them serviced the entire unit (fully disassembled) and replaced the solenoid within. Retightened and tested. Shop gives 110% confidence it will work and last the next 3 years at least. Re-installed the starter, VRROOOM! Confident first crank started the engine. Paid workshop 45GBP for service and parts. Another workshop for detaching and re-install another 30GBP. All in all, 2 hours down time only!
Well worth every cent...
at last...
desmondsee
