Timing, Idle n/a
Timing, Idle n/a
Postby ppete100 » Wed 18.04.2007, 17:51
looking for info on timing for my n/a. Have seen the forum write up but there's no mention of the n/a model. I' assuming that the procedure is different to the se model. Have also had a problem with idle speed engine tickover sometimes drops and then stalls, only happens occasionally any ideas would be greatly appreciated.
thanks
pete smith.
ppete100
Postby Oliver » Sat 21.04.2007, 13:09
Hello,
The ignition timing setting for the NA is 16 degrees BTDC.
This should be checked at normal operating temperature with the engine running in field service mode (short out pins A and B on the ALDL connector behind the glovebox)
The distributor clamp bolt should be tightened to 24 Nm (17 lbf.ft)
My idle speed occasionally flutters about. I replaced the IAC valve with no improvement. Is this problem a characteristic of this engine ?
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
re: idle/ na
Postby ppete100 » Sun 22.04.2007, 21:10
:) thanks oliver, stalled a few times today having it checked tomorrow, will let you know the outcome cheers,
pete
ppete100
Postby clemo » Sun 22.04.2007, 21:41
following thread if i can be of help
clemo
clemo
Postby ppete100 » Mon 23.04.2007, 20:05
thanks guys, had it checked over today, turns out the rubber strap holding the expansion tank is naff allowing the tank to drop onto the coil which is directly below it. :evil: Over time it has rubbed away at the connection resulting in an intermittent contact. The connector has very nearly burned away.Tried sourcing a new coil.. usual places nobody has one it seems. Temp repair underway until new coil is fitted.... anybody have one? this would probably explain why the engine tickover was unsteady. timing was spot on as was tps. hope this helps
regards
pete
ppete100
Postby gmacz » Mon 23.04.2007, 22:03
A100E6040F Ignition Coil Elan NA 1989 58.83 19.50 5
A100E6040H Ignition Coil Elan NA 1989 73.19 19.00 7
These are in the Lotus Sale.
£19 and£19.50
Yours Gmacz
The NaeLan Gives You Nae Trouble.
gmacz
Postby clemo » Mon 23.04.2007, 22:11
they are also a single point coil made by blueprint for the dawoo essparoe.
from most motor factors.
clemo
Postby clemo » Mon 23.04.2007, 22:12
and so is the coil and the ignition module..
clemo
Postby clemo » Mon 23.04.2007, 22:16
also i fear (the worst case ) to bear in mind (is that the right bear?)
my ecu and coil went at the same time so if it continues then an "NA" meet and ecu swap may help.
as i say if the problem continues ..
hope it doesn't
clemo
Postby ppete100 » Tue 24.04.2007, 10:02
wow thanks for the swift response guys much appreciated
pete :D
ppete100
