I'd like to hear from a few people about how they've installed their door sills (if you've ever removed or replaced them that is). Specifically, if you've used the plastic mounting strip.
I believe the way they are meant to be installed is to first install the white/clear mounting strip with the plastic rivets. Then the door sill gets installed over that with some adhesive or tape or whatever. has anyone simply installed the sills onto the frame without the use of the mounitng strips? If so, what was the result? Any gaps, leakes, etc.? Better with or without the strips?
I'd love to NOT use the strips but I'm not sure what the result will be. Any feedback or thoughts would be appreciated. Thanks all!
