by Houdini » Sat 18.02.2006, 19:49
Need to access the back of the gauges and the dash access cover won't come off. I've turned the 2 screws every way possible with no success. What am I doing wrong?
I've even slid a small screw driver under hoping to feel when it's loose but nothing is working. After one hour I come to you for help.
Houdini
by Houdini » Sun 19.02.2006, 02:12
Fixed! Some boozo replaced the machine screws with sheet metal screws and it made it almost impossible to remove. Got it out replaced the volt and oil pressure gauges and waiting on the new boost gauge coming Monday.
Houdini
by rob » Sun 19.02.2006, 10:35
This must be a famous quote.
Houdini: "Access cover will not come off"
rob
by Doug » Tue 21.02.2006, 07:34
Rob wrote:This must be a famous quote.
new forum name needed . . .
- LEC Founder
by Doc Fizzix » Tue 21.02.2006, 11:04
Houdini wrote:Need to access the back of the gauges and the dash access cover won't come off. I've turned the 2 screws every way possible with no success. What am I doing wrong?
Have you ever had it off? Can you move the cover at all? It may be that the anchors for the screws gave way so the cover may already be free.
Just a thought
Doc Fizzix
by Houdini » Tue 21.02.2006, 17:30
Doc,
It's off now. I never had it off but someone did and they replaced the machine screws with sheet metal screws. How they got them in beats me but it sure gave me fits getting them out. I've since replaced the nut clips and have proper screws to go back in. Cover is still off until the boost gauge is installed.
Houdini
Return to Interior
