Gear knob!!
Gear knob!!
Postby vowler » Fri 07.09.2007, 16:26
A simple question with hopefully a simple answer.... how do you get the gear knob off???
Vowler
vowler
Postby Monty » Fri 07.09.2007, 16:32
Pull
IIRC on the original nob there`s a grub screw (allen key jobby) and then it actually screws of anti clockwise.
Postby M100 TWO » Fri 07.09.2007, 17:52
NO!!!! there is a small grub screw under the neck of the gaiter screw out and then unscrew the knob
M100 TWO
Postby M100 TWO » Fri 07.09.2007, 17:57
Nice one Monty :-D Elephant trap for wrinklies
:wink: john
M100 TWO
Postby Monty » Fri 07.09.2007, 20:07
Postby vowler » Sat 08.09.2007, 07:20
Thanks... If only everything else was that simple...
Vowler
vowler
