Sun visors
Sun visors
Postby vowler » Sun 14.10.2007, 16:15
Hi... am going to remove the sun visors... can hardly see out the screen!! Although its always sunny here ( in dubai ) it's hard to imagine when the sun will be low enough for them to be any use... With just a quick glance, i cant see how they come off... any advice? Cheers Vowler
vowler
Postby paulrwebster » Sun 14.10.2007, 18:13
Take the screws out.
paulrwebster
Postby Doug » Sun 14.10.2007, 19:26
there's a plastic trim cover that just pulls off (or carefully pry it with a small flat screwdriver so not to mark the surface). Under the cover there are 2 screws holding the visor in place. Remove them, remove visor, replace screws, and then replace trim and you are done.
Postby vowler » Mon 15.10.2007, 09:10
Thanks Doug... I knew like all elan jobs, it would be easy!!!
vowler
vowler
