Glove box lock and clip A082U7985F & B100V0348F
Postby GeoffSmith » Thu 14.02.2008, 00:37
These are Astra/Carlton based and there are a few references on LEC: #1 #2 #3
They're not cheap either (£30.92 and £7.81 + VAT in 2008).
Mine (S2) never shut or opened very well but I found it helped if I lifted the whole box up until....... the barrel of the lock fell on the floor. It's been in the ashtray until today and I've had it to bits. What a pile of crap!
The barrel has four flimsy levers which are aligned by the key. In the RHS of the barrel, there is a ~2.4mm diameter hole, approximately 5mm deep. I eventually fished out a ~2.4 mm x 10mm roll/spring pin from the lock mechanism. This is obviously why the barrel fell out, so I replaced the barrel and inserted the roll pin with tweezers from the side of the lock (with the latch pulled up) and pressed it home.
Nothing. Pulling the latch didn't release the catch so I fished the roll pin out and did some measuring. There is about 5mm from the outer diameter of the barrel to the catch release mechanism which is the distance the roll pin sticks out! :evil: No the wonder the damned thing doesn't work very well. I think the roll pin must not be pressed fully home to enable them to engage - so either too far in and it doesn't release or too far out and it drops out.
I can't find them anywhere - does anyone have a 2.4mm x 12.5mm or 3/32" x ½" or do I have to get agricultural with an angle grinder? :twisted:
Postby dapinky » Thu 14.02.2008, 11:33
Sorry, Geoff.
Even with the cold snap we are having today, I couldn't find anything that small in the garage.
And the narrowest roll pins i have are 1/8" (3.17mm).
Postby GeoffSmith » Thu 14.02.2008, 13:48
:-D Thanks for looking Dave. :smt023
Postby Specky » Thu 14.02.2008, 13:54
Geoff had this problem on my Volvo..
and the quick fix was............................
Use a drill bit shank :-D
Postby GeoffSmith » Thu 14.02.2008, 14:06
Specky wrote:Use a drill bit shank :-D
Cowboy! :-D
Postby Specky » Thu 14.02.2008, 14:08
Cowboy! :-D
I've only been one for about a Yeeeeeeeeeeeeeaaaaaaarrrrhhhh...
Postby GeoffSmith » Thu 14.02.2008, 14:08
Cowboy! :-D
Postby theelanman » Thu 14.02.2008, 14:28
Specky wrote:
Cowboy! :-D
I used the leg of a filing tray......needless to say that someone has a wonky filing tray :-D
Re: Glove box lock and clip A082U7985F & B100V0346F
Postby surfboardfiller » Tue 04.03.2008, 14:39
geoffsmith wrote:These are Astra/Carlton based and there are a few references on LEC: #1 #2 #3
Sorry Geoff, just read this! I re built mine and could do the same for you if you have all the bits. :wink: Let me know either way mate.
surfboardfiller
Postby surfboardfiller » Wed 05.03.2008, 16:32
Fine, ignore me then! I'll help you weather you want it or not! :wink:
http://www.lotuselancentral.com/forum/v ... hp?t=11947
surfboardfiller
Postby GeoffSmith » Wed 05.03.2008, 18:15
Sorry Phil, just read (and registered) this! I haven't taken the whole lot apart and all I need is the right length roll pin which fixes in the barrel and activates the release mechanism. A kind hearted sole did send me a roll pin, but it was a tad too small diameter.
It's a low priority so it's still on the todo list.
Postby surfboardfiller » Wed 05.03.2008, 19:06
geoffsmith wrote:Sorry Phil, just read (and registered) this! I haven't taken the whole lot apart and all I need is the right length roll pin which fixes in the barrel and activates the release mechanism. A kind hearted sole did send me a roll pin, but it was a tad too small diameter.
My cousin has an old Astra he's breaking, so I'll see if I can get his lock and then you can have the pin off this key less one I have! :roll:
surfboardfiller
