Bonding the dash and surround
Postby CJ101KT » Sat 28.06.2008, 13:13
The soft outer dash has pulled away from the plastic solid dash itself to the lower right of the steering column. I am trying out several adhesives to try and clamp the two back together but would like to know whether anyone else has had this problem and managed to solve it?
Ta in advance ...
CJ101KT
Postby Rogerf » Sat 28.06.2008, 19:51
Yes, i used black silicon and 'g' clamped it over night.Still holding and looks good. :D
Roger
Rogerf
Postby CJ101KT » Mon 30.06.2008, 15:20
How did you get a clamp to stay on? I can't get a right angle and even adjustable clamps slip off after 20mins :(
CJ101KT
Postby Rogerf » Mon 30.06.2008, 22:58
To be honest i can't remember :?
My pattern maker did it for me and i think it involved a bit of packing :roll:
Rogerf
Postby firebobby » Wed 02.07.2008, 21:12
I used black silcone myself :-) Worked a treat, I used mole grips and some soft material to clamp. In the hot garage (sunny day) it went off inside an hour. Looks 100% better now. I also made a decent job on the A post. I put some cling film along the window, shut the door, run a bead of black silicone and then folded the clingfilm over it toward the screen. Left it till it went off then gently pulled the clingfilm off. Looks a lot neater now.
firebobby
