Fed Steering wheel conversion
Postby klassykappa » Mon 07.07.2008, 23:01
Well I guess this weekend I became the test dummy for everyone here in the us wanting to get rid of their airbag steering wheel and fit it with a MOMO or aftermarket wheel. Well I did it and I'll upload pics soon. First of all, you need the MOMO HUB/BOSS for a Isuzu truck. The number is 7903 Then you need a mom wheel etc for the hub.
1.disconnect batter and airbag fuse ect. If the bag blows in your fact ur in trouble
2. Remove the 4 screws from the wheel and remove the airbag. They take a star type wrench to do so
3. remove the 18mm bolt in the center of the stock wheel and remove the steering wheel.
4. remove the black plastic over around the column with 2 screws under the column. You may want to reemove the knee pad as well
5. remove the 3 screws of the plastic on the column. You will know it when you see it. It's so when you use your blinker and turn the wheel, it clicks off the signal.
6. Behind it I think may be another couple of screws but can't remember. Anyway the point is to get to the plastic cone in the middle and remove it. Once you do Cut it down, I used a carpet cutter about 3/4 of an inch. You may also want to shave it down on the inside about 2mm because its a very tight fit around the hub.
7. do steps 5 - 3 in reverse order and tighten down the momo hub.
8. Finally install your steering wheel and connect the 1 positive wire to the horn.
9. Now you are finished.
NOTE: The hardest part of the modification is hollowing out the plastic piece and cutting it down with a carpet cutter. :-)
I was weird at first having a smaller racing wheel but it looks WAY better than the stock fed airbag wheel. I also have a lot more leg room in the car now. Again, I'll post pictures soon but know that I'm no profession and I did this modification in less than 2 hours. So now there is proof to the FED owners that the 7903 isuzu momo hub will fit our cars. Good luck!
klassykappa
Postby tweetdriver63 » Mon 07.07.2008, 23:06
klassykappa wrote:So now there is proof to the FED owners that the 7903 isuzu momo hub will fit our cars. Good luck!
There are a lot of folks who will be thrilled to know this. I'd love to change my steering wheel, but since an airbag saved my life 3 years ago, I would never go without.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
