Keeping Cool
Keeping Cool
Postby Simon_P » Thu 31.07.2008, 10:18
Having Just driven across europe in 34oC and sunshine I found that the interior got quite hot.
Does anyone have any tips for keeping cool?
Thanks,
Simon
Postby Gary » Thu 31.07.2008, 12:50
Buy one with Air con ? 8)
Postby Sy V » Thu 31.07.2008, 13:56
Drop the soft top down?
Postby firebobby » Thu 31.07.2008, 17:07
:agree: :-D :-D :-D
Failing that driving naked may help??
regards
firebobby
Postby tweetdriver63 » Thu 31.07.2008, 17:26
firebobby wrote::agree: :-D :-D :-D
regards
Just don't forget the sunscreen :shock:
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Re: Keeping Cool
Postby dapinky » Thu 31.07.2008, 19:24
Simon_P wrote:Does anyone have any tips for keeping cool?
Go on hols in December :-D
Re: Keeping Cool
Postby GeoffSmith » Thu 31.07.2008, 22:48
Head North.
Postby Rambo » Fri 01.08.2008, 10:53
What about taking a shower with all your clothes on ? Then go driving with the roof down and the evaporative effect of the water being removed at +70 mph will certainly cool you down ;-)
Re: Keeping Cool
Postby Simon_P » Sun 28.09.2008, 02:32
Sorry for the delay in replying.
Doing 1000 miles in a day renders most of the suggestions impractical.
The Lotus just seems to get much hotter than other cars and I was looking for ways to keep the heat out in the first place.
I have aircon but sat in a traffic jam it couldn’t keep up.
Re: Keeping Cool
Postby ektrolleyboy » Mon 29.09.2008, 00:13
Most A/C is pants in that kind of midday heat whilst sat in traffic. On the move it's not so bad... But when you get to 36 degrees, after that A/C in the heat of the day is pretty poor car in every car I've tried except for the Japanese/Korean stuff. So look into the prospect of a compressor from a cheap Jap' car. Sounds crazy but I can promise you they're the best and put German exotica to shame!
I know because I'm just coming out of the other end of a summer that tops 40 degrees plus and 100% humidity on days.
Also a big help is window tint/ clear film. It's expensive but heat reflective film is a good buy.
Solar-guard.
3M.
V-Kool (probably the best).
Etc...
Pacific Blue-LOTUS ELAN S2 # 036 / Hot Orange-MINI COOPER S CABRIOLET
ektrolleyboy
Re: Keeping Cool
Postby rip » Wed 01.10.2008, 18:13
Simon_P wrote:Doing 1000 miles in a day renders most of the suggestions impractical.
Why?
Re: Keeping Cool
Postby Elanlover » Fri 03.10.2008, 14:05
Dynamat (or other sound/heat insulator) under the carpet and on the firewall will help. Make sure your heater fans position is set to recirculate and the temp control isn't on high.
Re: Keeping Cool
Postby Bolsom » Fri 03.10.2008, 17:57
Bonnet/hood vents?
Bolsom
Re: Keeping Cool
Postby tweetdriver63 » Fri 03.10.2008, 20:01
ektrolleyboy wrote:A/C in the heat of the day is pretty poor in every car I've tried except for the Japanese/Korean stuff. So look into the prospect of a compressor from a cheap Jap' car. Sounds crazy but I can promise you they're the best and put German exotica to shame!
Not that it really matters, but he's already got a jap one in there.
'91 Elan SE
tweetdriver63
Re: Keeping Cool
Postby ektrolleyboy » Wed 22.10.2008, 06:32
You know. It's funny!
All A/C is pretty poor in the height of summer here in the Middle East and you need to be in the car and moving for at least 20-30 minutes before you get decent cooling. Stopping in traffic is a no, no. But... The cheapo Hyundai's and the Toyota's etc. Etc. Have the best A/C you can imagine. I have no idea why.
My MINI COOPER S is dire, as have been every other car I've owned except for a hand me down Hyundai I once ran. I used to be a dealer here in the UAE and even Rolls Royce's are pants. The Pacific rim and Jap' stuff etc. Are untouchable for A/C performance. Now why other manufacturers can't compete I don't know.
Someone must have some technical knowledge about this one?
ektrolleyboy
Re: Keeping Cool
Postby nitroman » Wed 22.10.2008, 22:49
ektrolleyboy wrote:You know. It's funny!
With the "new" (since 1993) R134a refrigderant the vent air will only cool in direct proportion to the condenser temperature. The condenser is the A/C's "radiator". That is why, when the temp outside has heat-soaked the condenser to a high centigrade, it takes 20 minutes of cooler moving air to remove that heat & have a temperature gradient high enough that the R134a can shed heat through a cooler medium.
The old R12 refriderant was 3 times as efficient at removing heat, and so could still do its job even with a hot condenser.
nitroman
Re: Keeping Cool
Postby ektrolleyboy » Thu 23.10.2008, 00:56
I had a feeling this was the case because a car parked under cover in the summer will cool fairly quickly. A car left in the open will be terrible at cooling efficiently!
But... It still doesn't explain why the Jap' stuff is so much better at cooling? And believe me, there is a huge difference between let's say. A Toyota Echo versus a VW Golf. As just one example...
During the cooler months most cars perform pretty well, but once the summer comes (the kind of temp's that most on here wouldn't know about driving in) there's a clear distinction in the A/C world! Why? Why can't a BMW 5 Series cool as well as a similarly sized Toyota or Hynudai? And in this case a Lotus Elan...
ektrolleyboy
Re: Keeping Cool
Postby algirdas » Tue 28.10.2008, 06:53
Dear Ektrolleyboy:
Unfortunately, I learned more about A/C this summer than I ever wanted to know. Most of those observations will be in another post. My Elan is still on R-12 with a rebuilt compressor, a fresh receiver/drier and a long Saturday's worth of attention from a seasoned A/C pro (not me). First, my Elan now cycles between 33 and 39 degrees F on the center vents with the top up and the outside temperature at 90 degrees F in stop and go traffic.
Second, and this took me a while to understand, but the A/C system cools the car's interior not by introducing cold air into it, but by sucking out the heat and moisture. I realize that this may be a restatement of the incredibly obvious, but it was an epiphany moment for me.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Re: Keeping Cool
Postby DeanG » Fri 31.10.2008, 00:49
On the practical side, proven in high altitude heat and sun and low altitude HEAT and sun (Colorado and Death Valley). When parked, use a car cover. Put a cotton towel on the center arm rest. Wear light weight long sleeve shirts with collars to keep the sun off.
My unresolved A/C problem is related to a vacuum leak. Someday our M100 will work again.
DeanG
Re: Keeping Cool
Postby surfboardfiller » Mon 03.11.2008, 18:07
My solution is to get a white hood or line the one you have with some sort of insulating material. There is a really good product used in loft insulation which looks like fabric wadding with a foil layer (quite thin). It's safe to handle and doesn't break up - unlike older insulation material.
My AC used to work well, but the gas was replaced with the new wonder stuff and now it's useless! :evil: :roll:
surfboardfiller
