I just wish that we could have got the seats half inch nearer the centre of the car, but alas it is not to be. You may need to trim the seat belt holders on the seat shoulder to clear the side window. Do not remove it
as trying to reach the belt without this in place is a non starter for me! The seat will not sit inside the b pillar due to the shape of the seat shoulder , so rearward movement is restricted. This is still a great improvement over the standard seat.bobbrown wrote:As far as the bolts go I would just give them back as the chances of them being the correct length is going to be very slim and there are three different lengths on the original seats. 2 inners are M10 x 40, the front outer is 45 and the rear 50, the longer rear is due to the slightly taller spacer and NOTE you do need spacers to save stressing the floor.
You need to be carefull with the inner pair as they go into captive nuts and they can not be too long as they are into an enclosed section so the lengths need to be calculated from the originals but not too long!
I made these up for Jim complete with some short spacers and bolts sized to suit, I've got some more to make so if you want a set let me know by email
The cut out along one bar is to clear the seat so it does not foul on the bar.
They did take a minor modification to the original runners, but was simple enough, just remove the rear mounts and drill the rivet hole out.
They go at the outboard rear. The rear, nearest the door.
cliff wrote:Easiest way to resize pictures if you have a windows pc is to:
right click on picture thumbnail (or pictures), click send to, then mail recipient. This will open a dialog box asking you which picture size you want, I normally use 600 x 800, select attach. Outlook will open, copy the attached pictures to another folder. All pics nicely resized.
