instrument removal
instrument removal
Postby Mr Fixit » Fri 08.05.2015, 09:28
The three dials on the dash hash slight rust on the bezels and I need to sort this, can somebody let me know how much of a job and how to remove these please
C55 AMG Black
Lotus M100 red
Mr Fixit
Re: instrument removal
Postby Fredjohn » Fri 08.05.2015, 10:27
Not a technically difficult job, just requires nimble fingers, double jointed neck and patience. I removed mine recently to change the dial faces.
You'll need long nosed pliers, small mm sockets/spanners, screwdrivers and a bagful of patience.
Remove panel on top of the dashboard: 2 screws at the front.
Once removed, you can see the rear of the 3 dials. Each dial has a retaining bracket and 2 nuts, plus wires.
Start with the voltmeter and work across.
Carefully undo the 2 nuts that hold the retaining bracket and remove. Be careful not to drop them and their washers!!! Remove the panel light-bulb holder (twist and pull). A small mm socket will help with replacing the holder.
You should then be able to pull the dial out with wires attached. If wires are too short, remove first rather then after, making a detailed note of the colours and where they go(!)
Once out and detached you will see the bezel is crimped onto the plastic body of the dial. You need a small screw driver to carefully uncrimp it all the way round. Alternatively leave it on, sand down to remove rust, mask-up and respray with Halfords Satin Black spray. This is almost identical to the original finish.
Replacement is the reverse of removal.
Top tip: stand on seats, hands/arms below windscreen, head/face above windscreen looking through it at what you are doing.
You can also get chrome bezels to replace the black ones. I don't know where from though, as an unfitted set came with the car when I bought it. Still to fit them though.
Hope this helps and good luck
Postby epipete » Fri 08.05.2015, 11:25
I wondered about this, be nice to know where they are from.
Postby Saltire » Fri 08.05.2015, 21:17
Like this?
https://www.merlinmotorsport.co.uk/p/vd ... s-a2c53186
Postby epipete » Fri 08.05.2015, 22:24
Now that is interesting, especially as they are down at Castle Combe, which is very local. :bananasex:
Postby Saltire » Fri 08.05.2015, 22:38
epipete wrote:Now that is interesting, especially as they are down at Castle Combe, which is very local. :bananasex:
Indeed; I am hoping they may be around next Saturday morning . . .
Postby Kathryn » Sat 09.05.2015, 00:08
There is a link in the products for sale section for these. Just got round to buying some having been watching them on eBay for ages. I've already got the dash surrounds but yet to fit.
Palacio S2 #540
Kathryn
Postby Mr Fixit » Fri 15.05.2015, 22:52
those are for the view line range of vdo gauges and I'm not sure that will fit, check the diameter
C55 AMG Black
Lotus M100 red
Mr Fixit
new dash done!!
Postby Mr Fixit » Mon 18.05.2015, 10:10
refurbished the old dials and installed lockwood fascia.
C55 AMG Black
Lotus M100 red
Mr Fixit
Re: new dash done!!
Postby epipete » Mon 18.05.2015, 10:32
Very nice. :clap:
Now, about those speedo clocks....... :P
The problem is, where do you stop?
Postby Mr Fixit » Mon 18.05.2015, 19:10
now there's a thought, recon they'd be in quite quickly as I've done it before!! :lol:
C55 AMG Black
Lotus M100 red
Mr Fixit
