Mystery Find in the Driver's Footwell
Postby Dom » Thu 24.08.2017, 14:49
Afternoon, All.
I found this object in my driver's footwell yesterday, and am puzzled as to what it is. I think it fell out from behind the dash somewhere. There were also what look like two rivets lying nearby.
Can you identify it, please?
Many thanks,
Dom
Dom
Re: Mystery Find in the Driver's Footwell
Postby dapinky » Thu 24.08.2017, 16:23
Dom,
It is what is known as a Big Head Bolt (they do nuts aswell). Designed to be bonded onto a surface that needs a thread - often used in Marine applications and fibreglass cars.
Not sure where that one has come from, as it looks remarkably clean - the only ones I know to be used on the Elan, are on the front clamshell inside the headlamp pod bracketry - although it's quite possible that they could be glued/bonded to the dashboard for some application or other.
Postby lotusflasherman » Thu 24.08.2017, 18:20
Has yours got Aircon ? Parts Manual seems to show them being used to support the evaporator unit... maybe they were riveted and not bonded - looks too clean to have been bonded and broken away. Can you see where rivets were?
Postby Dom » Thu 24.08.2017, 18:24
Thank you for the replies. Mine has no air conditioning. The bolt was on the floor below the clutch pedal, with the rivets further to the right. I can't see where it might have come from, I'm afraid.
Dom
Postby cliff » Fri 25.08.2017, 09:10
Hi Dom
There are 2 of these securing the fascia, as you found it in the footwell, it might be the one holding the right upper side.
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby Dom » Fri 25.08.2017, 11:37
Ah, that could well be it. It happened after I fitted some foam to fill the usual "dash gap", which may be a coincidence, or may not be! The right side of the dash has always sagged a little compared to the left side, too. Maybe this is why.
Dom
Postby Dom » Fri 25.08.2017, 11:38
Oh, and how do I reattach it?
Dom
Postby lotusflasherman » Fri 25.08.2017, 11:54
Dom wrote:Oh, and how do I reattach it?
Big 'pop rivets'..
by 'Big' I mean something like 6.4mm ... www.ebay.co.uk/itm/6-4mm-Aluminium-Steel-Domed-Head-POP-Rivet-Blind-Open-Rivets-Choose-Length-/182280226193
Postby dapinky » Fri 25.08.2017, 12:18
As they are designed to be bonded (hence the holes in the flange to allow the 'glue' to grip) - I would just see what it attaches to, clean it up and use a big blob of sikaflex.
Postby clemo » Fri 25.08.2017, 14:06
Add lightness .
If its fallen of and its still standing then its over engineered . Throw it in the bin !.
(or put on shelf)
clemo
Postby Dom » Fri 25.08.2017, 17:17
clemo wrote:Add lightness .
(or put on shelf)
Tempting, as nothing seems to have changed.....yet....
Dom
Postby clemo » Fri 25.08.2017, 22:07
(or put on shelf)
thumbs up picture thing .
clemo
