Gear lever and handbrake gaiters
Postby jgbff7 » Wed 03.08.2022, 08:11
My understanding from studying the wealth of info here is that the gear lever gaiter is the same on the SE and S2 but that the handbrake gaiters are different. I have a S2.
So far as the gear lever one is concerned I have found reference to the wire hem being clipped into clips under the lip of the centre console, but I have no such clips. Did the S2 have clips? Other than glue I cannot see a way of holding the base of the gaiter in place.
So far as the handbrake gaiter is concerned, the S2 has a plastic piece to which the leather is glued (and not the wire which the SE has). My question is how that edge is held to the centre console? Mine has a cable tie at the rear end, but apart from that, the gaiter just flaps about. Is the leather face of the plastic hem glued to the console and/or clipped as well? To do the job properly the console will have to come out, which is not a big deal.
I bought a replacement handbrake gaiter from ebay which was advertised for M100 cars 1989-1996, but it turned out to be suitable only for the SE.
Many thanks
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Re: Gear lever and handbrake gaiters
Postby Tuga2112 » Wed 03.08.2022, 12:00
I Will take a couple of pictures of mine and post later.
Mine is a SE and i know the S2 console has a different design (window controllers in the front middle, by the sides of the mirror instead of the sides) so, theres a possibility the whole way to attache the fabric is different, But im hoping with some pictures of the SE you at least get a starting point to investigate from
Postby Saltire » Wed 03.08.2022, 18:32
I have an S2 as well, and I’ve previously replaced both gaiters.
The gear lever gaiter on mine has a stiff wire running around the base of the leather. There’s a rolled metal recess at the front and rear of the base of the gear lever. I managed to finagle the wire into the recess with the help of a couple of plastic trim tools, but it’s a right faff. :evil:
As you say, the handbrake gaiter is glued to the plastic strip and, on mine at least, the strip is fixed to the plastic console with 8 or 9 knock on edge clips like these.
Hope that helps :D
Postby jgbff7 » Wed 03.08.2022, 18:43
Thank you very much. Yes, that helps a lot. I shall get the console out and do a proper job.
Many thanks
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Postby jgbff7 » Thu 04.08.2022, 12:07
Does this look right? I wonder if the gold piece is upside down or back to front. The curved part is at the bottom for no good reason that I can see.
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Postby Tuga2112 » Thu 04.08.2022, 12:52
My SE has that as well. but from memory, its not shiny silver color, I Think mine had been painted black
Postby sheriff464 » Mon 26.06.2023, 21:45
Hello, I need to replace the hand brake cover on the S2; which over the 28 years, is looking a bit worse for wear! ( the leather has worn through on the left side!). Is there a supplier around that makes the hand brake cover and one for the gear stick also? Preferably in Grey, (Raven, I believe). Many thanks for any leads! Oh, also, how to remove those two pesky pop rivets at the front of console? Cheers from Clive.
sheriff464
Postby Saltire » Tue 27.06.2023, 07:21
Hi Clive, I got mine from eBay. It’s a long time ago, but they were like these ones. These are black, but I guess they might do dark grey if you asked nicely. Alternatively, I would think a decent local trimmer would be able to run something up for you fairly cheaply - Aldridge in Birmingham would be worth a call.
Good luck!
Postby sheriff464 » Tue 27.06.2023, 21:28
Jonathan, thankyou for the lead on the hand brake lever and gear stick gaiters. I have emailed The-tuning-shop-team and asked if they can do them in Grey leather, (Raven), I believe was Lotus' name for the S2 leather interior. I await a reply from them! Priced at £ 28.99p; I would say that is GVFM. Cheers from Clive.
sheriff464
Postby Graaf » Wed 28.06.2023, 17:26
sheriff464 wrote:Hello, I need to replace the hand brake cover on the S2; which over the 28 years, is looking a bit worse for wear! ( the leather has worn through on the left side!). Is there a supplier around that makes the hand brake cover and one for the gear stick also? Preferably in Grey, (Raven, I believe). Many thanks for any leads! Oh, also, how to remove those two pesky pop rivets at the front of console? Cheers from Clive.
I had mine made up at Allon White and they did a great job.
Graaf
