New Blaupunkt retro radio!
Postby HJ2 » Wed 26.10.2022, 17:23
This is a nice fit for our little M100:
Red backlit! & time correct (ish)
I’ll take it please!
https://youtu.be/r-Azisojpjo
Re: New Blaupunkt retro radio!
Postby Hector2021 » Wed 26.10.2022, 22:47
This Blaupunkt range does look good for the correct period look. I just received a 'Milano' model but the connector on my previous stereo dosent fit it. Ive just had to order an iso lead and will need to joint it into the loom now. Job for the weekend :D
NMY 1995 S2 No:490
Hector2021
Postby HJ2 » Wed 26.10.2022, 23:17
Yeah. Basically convert the car-side to ISO.
A couple of hours of fun, but then you can plugin about every radio you fancy :-)
Postby chrism » Fri 28.10.2022, 19:55
Folks, please don't don't think this is a 'mine's bigger than yours' moment but I've found a modern DAB/DAB+ radio with USB/phone/whatever-you-like etc that isn't 'blingy. It looks quite retro and matches the dash illumination perfectly.
It has an easily detachable face-plate if you worry that the purists are feeling 'gouty' at a show. It's quite short (since there's no cassette; the USB is under the arrowed flap on the rhs) so it's easy to fit into the limited space and (imo) very good v-f-m.
Yes, of course, why would we want ICE (with the hood down with 'our' exhausts)? - But I've sometimes listened to radio + USB topless whilst 'er indoors' is in the supermarket - and it's also a good listen with the hood up (very rare!)
It's a Pioneer MVH-S420DAB with a cheapy eBay amplified splitter plugged behind the set so I can use the original aerial. I don't get any signal loss. Just sharing...
Plus the option of phone connectivity (it's supplied with a discrete mike) - might be appreciated by those whose life could be meaningless without...:wink:
ps plug-'n-play w/out any need to change connector type
chrism
Postby HJ2 » Fri 28.10.2022, 20:42
Postby chrism » Fri 28.10.2022, 21:41
Aaah...okay... :-)
chrism
Postby Hector2021 » Sat 29.10.2022, 09:19
The main reason i liked this Blaupunkt range is due to the relatively large buttons that don't take more than a second to find and the matt black finish. My current Kenwood has the smallest and fiddliest buttons and a glossy faceplate that seems to always be masked by reflections. The Blaupunkts also offer hands free (might not be much use but ill find out) USB and Bluetooth.
Theres still a lot of choice out there for single DIN stereos and everyone will like something different. I like e to retro look and easy to use features of this... But then i am an old duffer.
NMY 1995 S2 No:490
Hector2021
