by Symfona » Mon 21.11.2005, 19:25
My driver's side seatbelt latch is sticking and I have to use my car key to get it raised so it latches properly. Any ideas or replacement options? SJ does not carry - used parts?
Symfona
by Doc Fizzix » Mon 21.11.2005, 20:37
Did you try to take it off and clean it out with some WD-40?
Give it a try
Doc Fizzix
by Symfona » Mon 21.11.2005, 23:08
I did spray it with Silicone but it did not help. I called the local Lotus Dealer who informed me the rights to the seatbelt patent had been purchased from Lotus and he gave me the number to order the entire assembly for around $165.00. All I need is the latch and would rather get a used one for about 25% of the new price. I may take off this weekend and give it a look.
Symfona
by Doc Fizzix » Mon 21.11.2005, 23:37
Take is off, I am sure you can get it working a little better
Doc Fizzix
by Doug » Mon 21.11.2005, 23:57
Mark A replaced his belt latch with a new stock from an Infiniti I30 (95% sure it was that) -- so check your local Nissan dealer and they will likely have something to fit. Mark said it is nearly identical, but it is not the same completely (meaning scrutiny can tell the difference but not with a quick glance). You get the idea . . . .
- LEC Founder
