by Specky » Tue 04.04.2006, 21:00
After a cold wet winter in the garage I just put the old girl on the road ..
And this is where the problem lies. I have condensation in all three small centre Gauges and this is really annoying especially when driving at night, hence the red mist..
Are the gauges sealed units?
Is it possible to remove the glass from the gauges in situ?
Any advice gratefully received..
by Jodie » Tue 04.04.2006, 21:08
The condensation will soon dissapear. It is due to a combination of cold weather and very little useage. There is nothing you should be doing about it.
Jodie
by Paul.P » Tue 04.04.2006, 21:12
Dave, i think this is quite normal in our climate, but if you really want to take them apart i know Monty has done this, so might be worth sending him a PM ?
by Specky » Tue 04.04.2006, 21:17
They alternate between "moist or stained"...
I really just want to clean em...
Cheers Paul P
by Paul.P » Tue 04.04.2006, 21:23
I used to get this a bit on my old white elan, but cant say i get it on blacky, don't know if its anything to do with the fact she has a shower cape on ?. Pretty sure when you get her out in the fresh air it will soon go !
by John_W » Tue 04.04.2006, 21:49
Dave,
see here
http://www.lotuselancentral.com/lec/mistygauges.htm .
As with most things on the Elan, somebody on LEC has been there and done that; Monty probably even has the T-shirt available for purchase.
- Heid-bummer
by Paul.P » Tue 04.04.2006, 21:57
Good find John, will remember that when putting white dials in !
by Specky » Tue 04.04.2006, 22:04
Superb answer... job on...
by GeoffSmith » Tue 04.04.2006, 22:52
John, I'm following you around tonight - just done exhausts & mistygauges.htm and now here!
I've only had mine 3 weeks (so she's been in the garage every night) and my dials have just started misting up. Page 42 of my manual has a section on ventilation : "It is not recommended to store a wet car in a poorly ventilated garage. If good ventilation cannot be provided, storage outside on a hard standing or under a carport is preferred"
I don't plan to attack my dials just yet but I'd be interested to hear how you get on Dave.
- Kitty Fiddler
by Monty » Tue 04.04.2006, 23:21
The gauges aren`t design to be pulled apart, so i wouldn`t advise on pulling them apart just cause there a bit misty as the mist will only show it`s ugly head again.
I`ve have a spare set of gauges and i`ve removed the dials (for paul.p to have lockwood make them up) i manage to chip the glass in one
If u do decide have a read of this:-
http://www.lotuselancentral.com/forum/viewtopic.php?t=6164&postdays=0&postorder=asc&start=0
- Chunder King!
by Specky » Tue 04.04.2006, 23:40
It doesn't look that hard
Cheers Monty
by ailwyn » Fri 07.04.2006, 12:09
Dave_Speck wrote:It doesn't look that hard
Neither does brain surgery
Ailwyn
- Forum Member
by johnbenk » Fri 07.04.2006, 23:50
Hi
Borrow the Hairdryer from you wife/son/daughter.
Heat Glass to evaperate excess water inside. This soon clears mist caused by condensation.
johnbenk
- The only Gay in the Village
by Doug » Mon 10.04.2006, 20:02
maybe you can get one that plugs into the cigarette lighter? :gray:
- LEC Founder
by Specky » Mon 10.04.2006, 20:12
Doug wrote:maybe you can get one that plugs into the cigarette lighter? :gray:
You can stop that for a start..
