Driving today, I noticed the speedo started to have its moments. At stop, I'd take off. The needle either stays at 0 or operates as normal. Once engaged, the needle continues to read until I come to a complete stop. Then it either works or doesn't.
While under way, it seems that the speedo might engage when I shift or hit an expansion joint in the concrete. This suggests to me the issue is mechanical and due to some worn gear somewhere.
Thoughts anyone?
